im also in the same situation. My shocks arent "gone" but the car is a 1994 so nearly 10 year old shocks arent gonna perform that flash. Also if youve put in lowered springs, you should change your shocks to match the spring rate anyway.
www.horsepowerinabox.com have some pretty decent Koni shockers that are adjustable. and for about a grand thats pretty good value. i believe non adjustable bilsteins are around that mark anyway, only a little cheaper.
https://www.sau.com.au/forums/topic/6394-shocks/#findComment-95818
if shocks are completely rooted, if you push on the car, it will bounce up and down until it gradually stops. But if a shock is just worn, which will be the case for most cars with a few years on them, then you wont be able to tell without a shock test from a suspension place.
https://www.sau.com.au/forums/topic/6394-shocks/#findComment-95821
I've generally found that once a shock starts to pass its use-by date, the ride becomes quite harsh - when you hit even the smallest of bumps, you get a sharp jarring through the suspension.
Checkout Whiteline for some new shocks.
https://www.sau.com.au/forums/topic/6394-shocks/#findComment-95848
Bilsteins are probably the best value performance shock you can get and they are rebuildable as well. Ohlins may be better but if they're priced anything like motorcycle shocks they will be hella expensive (Try >$800 for *one* Ohlins shock for my motorcycle!)
Should be around $1100 for all 4 corners for Bilsteins, but if you're replacing shocks you may as well get new springs too for another $200 or so. My old springs were rooted as well, the back was lower than the front, and the left side sat lower than the right!
I was originally looking for Koni adjustables which are around the same price as the Bilsteins but apparently you can't get them for R33 GTS-t's at present.
https://www.sau.com.au/forums/topic/6394-shocks/#findComment-95986
Hippy you can but and it will give better handling but due to the fact that they are lower it will stuff the shocks really quick. You can tell by looking at the shock where the rod that moves up and down goes and oil will leak from there.
Hippy pm me if you are looking for some springs or shocks as i get whiteline stuff. Clint
https://www.sau.com.au/forums/topic/6394-shocks/#findComment-96084
I was speaking to RPM perf centre a little while ago and they supply the koni adjustables. They are pictured and priced here:
http://www.horsepowerinabox.com/mall/sk16.asp
if you do some looking around, 1100 bucks for damper adjustable shocks is pretty cheap. The bilstiens are another BIG name, but they are still around a grand, and not damper adjustable.
While i knew bilstein were excellent (standard on mercedes and other expensive cars) I wasnt sure about Koni's credentials, but then i found out that Koni shocks are factory OE on Lamborgini Diablos! So they gotta be decent!
https://www.sau.com.au/forums/topic/6394-shocks/#findComment-96157
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
