Chilli EAT OFF! - Tues Feb 15th 2005
Are you unable to read? I thought I had made it quite clear, or do i need to do another "Follow my Pink Bits" mspaint masterpiece? ;)
Ska the smart ass.
So its in a building at the Hyperdome, like within the car park, or inside the Hyperdome it's self.
And yes pink bits map would be nice.
  • Replies 139
Ska the smart ass.
I like pink bits
Alrighty then follow my pink bits ;)
Mum would be so proud of that effort, didnt even have to use the text function, did the writing MOUSE style, could you notice? :(
The booking shall be made for "The Honourable Councilors for the Borrough of Harrow"
Haha you better, cause I don't want to look like a tool asking for that table when you really booked it under SAU or something ;)
Need 8 or more people to make the booking but will definatly make it for "The Honourable Councilors for the Borrough of Harrow" as it should be now duely noted in the minutes.
Could you point to the exact part of Cyrus' pink bits on which the M2 resides? I've already thouroughly inspected them myself, but have been so far unable to locate it, or anything else of significance in the general vicinity.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
