Come up with another idea for gauge placement...
I have also filled both dins with stereo/DVD head units, so was thinking bout alternatives... my clock doesnt work, so was thinking rather than fixing it (got a clock on the stereo of course) I might find a colour-matched dash-top moulded gauge holder to utilise the dip in the dash where the clock is...
So thinking maybe finding a dash-top gauge holder like from an FTO or something and shaving the bottom of it to match the lines of the clock indent... will see how I go and post pics :)
Anyone suggest any other cars that have stuck-on moulded gauge clusters I could try??
:D
https://www.sau.com.au/forums/topic/64085-guages/page/2/#findComment-1218884
  • Replies 52
2 x 2 1/16 gauges fit snugly in the ashtray hole, angled up and towards me :D They actually jam in there tightly and hold without any mounting at all, but for aesthetics I am getting a dash colour-matched plastic facia surround made up this week to close it in nicely. Heres a pic:
https://www.sau.com.au/forums/topic/64085-guages/page/2/#findComment-1238720
Yeah - good thing i dont smoke :cheers: Although you could always just use the rear-seat centre console ash-tray to butt out the ciggies - its actually less of a reach than the dash anyways!
And yeah - seeings my clock doesnt work and theres one on the stereo anyways - racking my brain about what to slip in there... an EBC would fit nicely too... hmmm
https://www.sau.com.au/forums/topic/64085-guages/page/2/#findComment-1239200
  • 3 months later...
I am a bit confused, need help, has anyone used the modyourcar single A pillar pod;
Does it end up looking like bukey22's?
(the small pictures on the previous page)
If anyone has (or maybe burkey22), would a 60mm gauge fit? I know it will overhang the outside of the POD face, but will it fit inside?
https://www.sau.com.au/forums/topic/64085-guages/page/2/#findComment-1410381
Here is my boost guage from Autobarn. Its 2" or just over. I origanaly had the boost guage and turbo timer under the cd player but I found it too distracting to look at while driving, and am very happy with the placments now.
Also I had to but a blue sleeve over the buld in the guage so it glows white not yellow/white, also from Autobarn.
https://www.sau.com.au/forums/topic/64085-guages/page/2/#findComment-1410644
This is a picture of the Din guage holder i'm getting. It holds 3 x 2 1/16 guages
Andrew,
After our chit chat on Saturday, I found this thread on the guage holder - have E.T.
Performance indicated that it will definately fit the Stagea's?
Regards,
Marc
https://www.sau.com.au/forums/topic/64085-guages/page/2/#findComment-1410916
  • 1 year later...
wow way to go dredge up an old thread :O:):D
glad to see a member who uses the search button
looks like single ones do but dont think the angle and the shape of a stagea pillar would make for a good fit and also the pillar is grey the pod you pictured there is black wouldnt look to good imho
https://www.sau.com.au/forums/topic/64085-guages/page/2/#findComment-2429731
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
