Recently i bought a second skyline, i thought to myself i need something that i can really work on, so i went out and bought a 96 GTS car is in excellent condition, now i thought to myself i either do a big turbo conversion or get a gtr engine in there. If i get a gtr engine id like to keep everything stock except the intercooler, boost and exhaust system and fool around with a new ecu. Whats cheaper? What is all ur opinions?
https://www.sau.com.au/forums/topic/64187-my-project-car/
if you wanna throw money around check out an rb30det conversion
use twin rb25 head (which you have) and rb30e bottom end to give you an rb30det
much more torque, more power and good wide power band, 3 litre should be sweet
rb26 will set you back $6000 odd? you should be able to do rb30det for around the same maybe a tiny bit less and it should be better in stock form
https://www.sau.com.au/forums/topic/64187-my-project-car/#findComment-1204006
check out below URL its a 40odd page thread for the rb30 conversion
its been done many times with good results, unsure of rwkw with stock parts
http://www.skylinesaustralia.com/forums/sh...ead.php?t=15420
https://www.sau.com.au/forums/topic/64187-my-project-car/#findComment-1204029
rb30 should able to be done at a lot lower cost than rb26 ... as you say 6k+ for rb26 or $+/- 500 for rb30e use the rb25 head you have, then all your support mods, fuel pump, injectors, ecu etc etc, prolly do the lot for under 3k ...
not talking from expenience, just from all the reading / research I have done ...
cheers
https://www.sau.com.au/forums/topic/64187-my-project-car/#findComment-1204570
