when im loading up the car in 2nd/3rd/4th sometimes the exhaust temp light flashes. so i stop accelerating, now when i press up on my hand controller to bring up "highest" rating during acceleration it shows little knock, like 20-30.
should i ignore the exhaust temp light?
there are 3 things that will cause the exhaust temp light to come on for R32
its covered in the PFC FAQ, its the same as the engine check light
the FAQ is down as the vhost is broken but when it comes back up, youll find what you need in there
Cheers for the FAQ mate.
Have an issue with my PFC on my r32gtr.
Its working fine in every aspect but it has ceased to display my speed. Any idea as to what could be causing this or where it gets it signal from. Have hooked up a mates hand controller but still no speed reading. Bloody frustrating as rely on it at trackdays for info as am usually concentrating too hard to read the speedo. LOL
Be great if someone could solve this for me.
Cheers
does the std cluster speed guage work?
i believe the FC signal and the guage cluster one come from the same source
or it coudl be a case the ECU gets the signal from the cluster
trace the wire to find it ?
R32 GTR gets the speed signal from the instrument cluster for sure. I broke the speedo cable and lost the speed signal. If I spin the input at the back if the speedo I can see the speed on the hand controller.
Edited by Waza_GTR
Yes i have changed the instrument cluster (how obvious, this was lost in all the other stuff i was doing ) That and i didnt think the signal came from the cluster but from a tach signal else where. Had to rewire the cluster too as was from a later model.
Many thanks Guys for putting me on the right path.
Cheers :)
You may have the speed sensor wires reversed on the new cluster. The newer model gtr cluster in my 89 bunky needed this (as well as all the rest moved that you already know about). The speed sensor is shown as a set of switch contacts on the wiring diagrams, but if you look on the back of the cluster on the circuit board you will see that there is a marking for a zener diode, that gives the hint, polarity conscious.
Hope that helps.. I can even show you which pins you need to swap if you can't find it as I kept my notes.
James.
the FAQ is back online;
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
i am no longer accepting pm's any more - i've had enough
if you want to know something about the powerfc search in the faq
if its not in there i dont know the answer
ive had too many pm's over the past few years
people dont put in the effort to search
thanks
Hi Paul,
i hope the above doesn't relate to the below as it's not a commonly talked about topic so not sure a search will reveal much? Pm me Paul if your have time to help, i realise i wont be able to reply to your pm
can you help me figure out which wire i need to connect for the TPS on my GTS4 with GTSt pfc
thanks Steve
two questions paul
1. Can a normal Power FC be used with a map sensor and some how converted?
2. i know this is not realy a power FC question but Power FC datalogist software do you have a list of all the features it has and can do? as i tried to contact the distributor as i would like to know what it can and cant do before buying it but all they told me was to buy it due to it being the best.
Hi Paul,
thanks Steve
search on google or my site for pin out diagrams for the rb20 ecu
then you just need to find the TPS signal wire
should take you all of 30 seconds searching in google or the forums for
rb20 pin out diagram
the wire is labelled "TPS" as you would expect
two questions paul
1. no it cant, the normal powerfc expects an afm, the djetro version expects a map sensor, you cant mix and match
2. this is covered in the powerfc faq to death, there is a massive topic on datalogit, i suggest looking in there - the url is on page 1 of this thread or in my signature
sorry about that
but thanks for the help
no need to be sorry its just im kinda over a trillion pms a week about the same stuff over and over
especially given its covered to death and detail in the pfc faq already -thats the point of it
your questions were fine as they arent common and arent listed in the faq
Hi Paul,
I have read carefully through the faq and i have a issue that was covered for the power fc not the power fc d-jetro.
Basically i have 3 bar map sensors on the gt-r and when i want to run more than 20pounds of boost they go off the scale on the hand controller as we are tuning...
So if we use the software on a laptop etc will we be able to fix this issue?
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
