use the cranking adjustment screen to mark it start easier when water temp is up
part of it might be in the FAQ or check out the documentation
i can look into if you like, but will take some time
Hey guys. Did a search and cant find the answer.
Do you really need a Hand controller. Apart from the information it gives you, Any harm in ditching the controller after a safe tune. Or buying a PFC with out one in the first place
1. no trouble form cops.
2. no one breaking into your car to steal it.
Thanks guys.
Thanks guys.
You dont need it, especially if you plan to get a reputable tuner to tune it, they will already have the right stuff to tune it via a laptop.
Thanks heaps mate. Exactly what i wanted to know
=D
i have had my PFC for about 5 years now and i also have datalogit
i have found the hand controller very useful for;
- checking peak boost to make sure my controller isn't spiking / being stupid
- checking levels of detonation
- checking water temp
- adjusting correction from time to time on water temp
- temp ign adjusts when excessive detonating occurs (shit fuel etc)
- checking ETC, SENSOR SW CHECK when engine check light comes on (my TPS is intermittent faulty)
- adjusting boost in summer, i had my duty set too high
and so on... without the hand controller i couldnt do any of that, nor could i actually see whats going on
without the hand controller, the PFC is basically the same as the stock ECU (minus the tune ability).
that is, everything is locked away, you have no visibility, and no control
even if you dont know what you are doing, the hand controller is such as a simple and powerful tool
you may find youll be wishing you brought the hand controller once you have it up and running
just be careful where you place and store it etc. you dont have to adjust stuff, but its great to be able to
and youll find it heaps easier to sell your PFC with a hand controller, instead of without one
fyi - ive left my hand controller on my dash, above the glovebox velcro'd there for about 5 years
have parked the car near train stations, shops, streets, in the city, carparks, work etc
this is with an RSM on the dash, VAFC on the dash and turbo timer and head unit and dvd player
not a single issue .... :D
hey paul just quick question, after reading ur FAQ i still want an answer from you!!! i have had a tune, n all is running ok, then i installed an EBC now i want to know what is a bad knock on the pfc? it dosn't knock much at all untill i come on boost then knocks constantly around 7 n sometimes a little higher...
LOL 7???? you have absolutely nothing to worry about, my tuner told me that if it constantly goes over 45 then i should get it checked, note the word constantly, the factory knock sensors have a habbit of picking up other noises and reading it as knock, so unless it is constantly high there is nothing to worry about, i have seen it as high as 111 once.
Also another take on this topic is that your engine could have a really safe tune, due to the fact that it reads a lot of other noises as knock a 7 could mean that your engine is no where near its potential and is in fact under tuned.
as said above, 7 doesn't sound too high, but its a basic microphone in the engine so it will pick up other noises
ive seen a knock level of 200 on my hand controller before, obviously thats bad of course.
60 will turn on the engine check light, so apexi decided that a knock of 60 or higher is bad enough to throw the engine check light on
its also possible there isnt enough knock, ie knocking is too low, which means the engine isn't tuned hard enough
Hi guys quick question, just trying to put some sard 800cc injectors into my R34 and trying to tune it. But it is having a few problems. It wont turn over and the injectors are not pulsing. could this be caused by the 1.60msec delay the injectors have as the PFC will only let us go 1msec delay max
you are viewing a BRAND NEW set of 6 Sard 800cc fuel injectors for use on the R34 body style Skyline GT-T equipped with the NEO RB25DET engine.
The injectors are top-feed, high impedance and an excellent upgrade for those going with a larger turbine setup.
The set comes with bolts and spacers designed to use with the OEM fuel rails.
Everything is BRAND NEW and in obvious perfect working order.
You will not need to worry about getting the items flow tested as the items are NEW!
LAG TIME 1.60msec
any help greatly appreciated
Edited by ian_and1
  • 1 month later...
Ok I've been doing a bit of reading regarding the Power FC Pro in the last hour as I possibly can get my hands on a second hand one (including controller)... It's for the 98.6~ RPS13 (180sx Type X).
Now there's a bit of concern going around as to whether ones people have received are legit Pro or not... Only way to tell is to turn on the PFC and check the start up to see if the text reads PRO (e.g. SR20DET1PRO or similar), or open the ecu and see if there's a sticker on the NEC chip with the word PRO on it...
As the guy is from Sydney and I'm in Melb, I can't do those things...
I'm hoping to clear a few queries I have:
1. Is there certain serial numbers for the PRO to tell them apart from other PFC versions? (for both ecu and hand controller)
2. Does the hand controller have to be a Pro version to suit the Pro ecu or all hand controllers can be used with all versions of the ecu as long as they are in the same generation?
3. Do the boxes and manual of the Pro differ to the standard Ljetro version (normal version)? I ask cos I have the standard PFC and would like to keep the boxes and manual for referencing the Pro, but if they do differ I'll include them in the sale of the normal when I sell it to get the Pro :)
Thanks in advance!!!
Cheers,
Andy
Edited by AnDyStYLe
sometimes there is a little sticker on the side of the but i dont think mine came with it and its only hand written
as for HC you need a 415-N001 model not the X001
if he has the original packaging it should look something like this
this is the FC packaging sticker
I'm helping a mate put an R32 RB26 in his R34 GTS. He already went out and bought an R34 PowerFC. I know that the R32/R33 & R34 have different part numbers.
Will the R34 PFC work with the R32 motor? What is the difference between the two?
3. Do the boxes and manual of the Pro differ to the standard Ljetro version (normal version)? I ask cos I have the standard PFC and would like to keep the boxes and manual for referencing the Pro, but if they do differ I'll include them in the sale of the normal when I sell it to get the Pro ;)
Cheers,
Andy
this is covered in the FAQ and was recently updated, you should check it
if the PFC case has a silver shiny FC Pro~~~ sticker on the side of the ECU case, this does NOT mean its an FC Pro unit, its just the software designation
so the only legit was is to check via what the hand controller displays, or as Madaz said, check the box packaging
Hi, just want to clarify... Should the power fc turn on when you turn your key to acc, or when you turn your key to on? I found three black dots in the censor check: ign, eccs and wrn. But everything still seems to work fine on idle, haven't driven it yet. I even tried to change some values in the injector chart, turned the power off and on again and the values remained changed so it saves the changes.
Anyway, my fc turns on when I turn the key to on, and I'm going to check the ignition and eccs relays and the pins 10,16,20,49,59,109 in the power fc that comes from these relays over the weekend. Any other ideas?
the FC wont turn on when you turn key to ACC, but it will when you turn it to ON
having IGN, ECCS and WRN in a state of ON (black dot) at ON is normal - there is nothing wrong
the black dot means the relay/switch is on, ie your IGNItion is on (yep youd expect that), ECCS is on (yep youd expect that, the ECU has power) and WRN is part of the warning check loop which means the engine check light is on - have you turned off the std boost kit? its covered in the PFC FAQ, turn the boost kit off and engine check light will go out away
Doesnt the Apexi boost controller kit for PFC gets controller via the handcontroller? Also I'm looking at getting a PFC Pro for the 33gtr but it doesnt have a handcontroller. My question would is, is the handcontroller for a normal PFC compatible with the PRO?
Handcontroller
http://www.skylinesaustralia.com/forums/Ap...87#entry4742587
PFC Pro
http://www.skylinesaustralia.com/forums/St...ar-t281327.html
Thanks!
lol yeah you cant tell shit with that serial number at least i cant
the serial on my PFC pro hc is FCC2NT 020-02598
but its model number is 415-N001 which is the old style controller there is a new style which is z x001 this is incompatible
yes the Apexi boost controller kit can be adjusted from within the HC
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
