Swordfish19792002 Posted February 11, 2005 Share Posted February 11, 2005 After reading a few posts about the coil pack issues i was wondering, 1. How much for new set of coils 2. Where can we get them from 3. Watt brand (Spitfires/Genuine nissan ?) Also O2 sensor & crank angle sensor....how much and where can we get it from? ................................................................................ .......................................... I got my car dyno yesterday at Jem performance at Moorebank NSW but I did the following before the dyno, 1. New fuel filter(coopers brand) 2. New BCP7E NGK Spark plugs.....(no adjustment on gap.. kept standard gap) 3. Reset the ECU It was dyno at 134 kw. A few adjustments and i got 145kw safely. Yes my car has got a pingin issue and missfire. ................................................................................ .......................................... I will try the following now; 1. Clean the injectors out (my car has done 101,000 km now) 2. Seal the coil packs (with either Araldite or that dialetic grease) 3. Change 02 sensor 4. Change crank angle sensor (? not sure about this one yet) I will do each in stages to c if there is any change between these items do. maybe we can hopefully isolate something. ................................................................................ ....................................... Have i left anything out? What do u guys think? Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/ Share on other sites More sharing options...
rd-runr Posted February 11, 2005 Share Posted February 11, 2005 1. Splitfire coils $650 delivered from nengun.com 2. 02 sensor $200 genuine nissan. Prices are for brand new parts. There are other cheaper options for 02 sensor. Do a search! Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-1205086 Share on other sites More sharing options...
madmoomoo Posted February 15, 2005 Share Posted February 15, 2005 I've been searching for O2 sensors too, and from these threads, lots of people have found that EL ford falcon sensors are a swap over, albeit with a bit of wiring. They range from $80-$120 from places like repco & autobarn. Aparently the wiring has a diff harness/clip, so you need to cut it and rewire. Seems pretty simple. This is what i'm doing later this week. Hope that helps. Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-1210514 Share on other sites More sharing options...
The Dan Posted February 15, 2005 Share Posted February 15, 2005 Looks like you have covered the common stuff. They are a cam angle sensor also, not a crank angle sensor. Not that anyone gives a crap, but sometimes helps when ordering parts. What boost level VS timing are you running? What mods do you have? Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-1210650 Share on other sites More sharing options...
Swordfish19792002 Posted February 18, 2005 Author Share Posted February 18, 2005 ok...... GTR Killer thanks. Thinkin of VL's too much. I started on my Injectors yesterday. I took the whole Fuel rail out and sent it in with the injectors in it to be cleaned. I found that in the manifold...the last 3 sections inside the manifold are quiete darker in oil. I am talking about the last 3 manifold sections closest to the fire wall. The first 3 are clean as. I am thinkin o gettin the head ported and polished a little ...while i have the stuff off. Not sure yet what to do. Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-1217271 Share on other sites More sharing options...
The Dan Posted February 18, 2005 Share Posted February 18, 2005 With that info I would have to definately recommend a head service which you will get with a port job anyway. The valves have to come out to do the porting so they will re-seat them and replace the stem seals. You will most probably find the nature of your problem once the head is off. Make sure you check your pistons for bore travel just to be on the safe side and check them for pitting or any unusual marks. Make sure you find out what's causing the darkness before you go ahead with the port job. Also make sure they do a full check on the head before proceeding. I know of a couple of places who would just start chopping without checking. Another thing about porting, on this vehicle it is not advised to extend the head VS manifold area. This, I have been told, is already quite large compared to the capacity of the head. Depending on how far you wanna go with it. Sure, if you have the turbo to match it, then open her right up, but be prepared to open your wallet at the petrol station. If you are going to open this area, make sure you match port the manifold to suit it otherwise your efforts are wasted. Most of your power gains will be made from cleaning up the bowl area below the valve. Do not underestimate such minimal work, you will be surprised at the results. Polishing is a bad idea....good in the 80's but reasearch tells us that pollishing the heads and manifold is actually bad for performance. You will lose horsepower with a polish. Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-1217498 Share on other sites More sharing options...
ANG32 Posted January 20, 2007 Share Posted January 20, 2007 what is 02 sensor, I'm new. Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-2839066 Share on other sites More sharing options...
salad Posted January 20, 2007 Share Posted January 20, 2007 (edited) There is a huge thread on O2 sensors stickied at the top of this section. Get N15 pulsar plug, $90 from motortraders (trade price) and comes with plug. Plugs straight in, no fixing wires I just got one and definitely does fit Edited January 20, 2007 by salad Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-2839095 Share on other sites More sharing options...
XMOr33skyline Posted November 3, 2010 Share Posted November 3, 2010 what is 02 sensor, I'm new. LOL Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5529591 Share on other sites More sharing options...
mad082 Posted November 3, 2010 Share Posted November 3, 2010 wow, thanks for digging up a thread from 2007 just to say LOL fkn idiot Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5529671 Share on other sites More sharing options...
Birds Posted November 3, 2010 Share Posted November 3, 2010 Bahahaha. Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5529716 Share on other sites More sharing options...
XMOr33skyline Posted November 3, 2010 Share Posted November 3, 2010 wow, thanks for digging up a thread from 2007 just to say LOLfkn idiot UMADBRO? Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5530541 Share on other sites More sharing options...
mad082 Posted November 4, 2010 Share Posted November 4, 2010 i'm always mad, hence the name Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5531864 Share on other sites More sharing options...
XMOr33skyline Posted November 7, 2010 Share Posted November 7, 2010 i'm always mad, hence the name so thats y u drive a skyline bro mad kent Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5536791 Share on other sites More sharing options...
mad082 Posted November 7, 2010 Share Posted November 7, 2010 actually i don't own a skyline anymore. i don't own any cars at the moment. Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5537808 Share on other sites More sharing options...
Birds Posted November 8, 2010 Share Posted November 8, 2010 Just a lot of permanent bicycles Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5538106 Share on other sites More sharing options...
mad082 Posted November 8, 2010 Share Posted November 8, 2010 well played, lol Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5538203 Share on other sites More sharing options...
XMOr33skyline Posted November 8, 2010 Share Posted November 8, 2010 well played, lol cars gettin 2 expensive were they? try not to stack em Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5539815 Share on other sites More sharing options...
mad082 Posted November 9, 2010 Share Posted November 9, 2010 don't see the point of owning 2 cars as the missus and i both work at the same spot (at my business), and her car is fast enough (will beat natro skylines, lol), and is cheap to run, and tows my tinny well enough, so no point paying $1000 in rego and insurance a year for a lawn ornament. oh and the bicycles comment was based on the fact i own a bike shop. Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5540055 Share on other sites More sharing options...
XMOr33skyline Posted November 11, 2010 Share Posted November 11, 2010 don't see the point of owning 2 cars as the missus and i both work at the same spot (at my business), and her car is fast enough (will beat natro skylines, lol), and is cheap to run, and tows my tinny well enough, so no point paying $1000 in rego and insurance a year for a lawn ornament.oh and the bicycles comment was based on the fact i own a bike shop. what are these 2 cars you speak of Link to comment https://www.sau.com.au/forums/topic/64245-r33-gtst-coil-packso2-sens-crank-angle-sens/#findComment-5543949 Share on other sites More sharing options...
