Where is the best place in Queensland to buy a skyline
  • Replies 53
Originally posted by jward24
So....
Where is the best place in Queensland to buy a skyline?
If you know a good dealership can ya tell me or is it best to import one....what is a good company to import a skyline for ya...
thanks
I bought mine through Phil (PRIMO) and he has been pretty good the whole way through of the importing process. He will let you know what is going on pretty much all the time. I recommend him if your looking at importing a car, very good to deal with.
Cheers
Sumo
try Asian Auto Spares on (o7) 32080133.
they have plenty of spare parts but import quite a few cars aswell including skylines, friend of mine bought r32 skyline gtst complianced and registered for $10 000, but that is mates rates of course. preety good condition aswell just needed a paint job had 90,000kms,17 inch wheels, exaust, filter etc.
givge em a buzz see what they can do for u.
Originally posted by chaos
anyone know good car dealerships in brissy or the coast the offer finance on cars??
A basic hint on paying for a car - DON'T use caryard finance!! It's normally horrendously expensive and not particularly forgiving if you read the fine print. They're often financed by places like AGC, I'll let you form your own opinions on that.
If you need finance of some sort (as most of us do), organise your own loan through a bank or similar. This also gives you the bonus of being able to bargain with cash.
Originally posted by banana
have u guyz heard of autoforce or ajm's???
Have heard of Autoforce but don't know them, and AJM is Auto J Mart. I can't vouch for or against either of them as I haven't bought a car from either.
I personally would still go through Steve (MR-GTR) if it were me.
Guest banana
Chad Barrett - Fast and Furious
Located at Tingalpa, southside of brisbane.
Mainly specialises in Skylines & Supras. I am importing a R32 gtst from him early next year.
www.fastandfurious.com.au
is tingalpa in brisbane??
never heard of the place??
what street on tingalpa:p
  • 3 weeks later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
