If any of you guys hear of or know someone who recently brought an rb25det out of the quokka please contact me immediately on 0404344855.
This motor was stolen from me and then sold in the quokka, i dont want to see some poor skyline owner get charged for recieving stolen goods or something stupid like that. Also it helps me retrieve my stolen engine and them get their money back as well as the idiot who did this to get charged with stealing or stealing a motor vechicle.
Thanks alot for your attention
https://www.sau.com.au/forums/topic/64476-stolen-engine-please-read/
you should advise all workshops and parts outlets that deal with lines and supply the engine number to the workshops. If the dude who bought it is oblivious of the fact that it is stolen he wouldn't be thinking of grinding off the e#.
Did you see the ad in the quokka, if so which week was it in. I'd like to see if my cousin could try to trace who owns, or owned the phone # used. More than likely a mobile which has been cut off now. But the phone company may have some details that could help.
thanks heaps for your support guys...
i know who stole it because he did an engine swap for me, he just decided he would palm off my engine and keep the money instead of letting me have it back..
the cops are already all over it and he doesnt have a leg to stand on, he even used his own mobile number and suburb in the quokka listing, he isnt the smartest of people...
ill post an engine number tommorrow...
it was advertsed in the quokka released on the 10/02/05 in the asian parts section under skyline, listed for $1500.. hes has/is trying to palm it off as a working engine when it has massive blow by due to a ring gone in number 1.
some people eh?
luckily you've got alot of ammunition on your side so prosecuting the guy won't be a problem, i'm sure as soon as the guy installs this engines he's going to see it doesn't work and then alot of word will go around of trying to fix it.
just for good measure whose the guy that ripped you off so that we all can blackmark anything him of his friends do ever again.
You realise that the worst thing the person can do is own up to buying the engine? If they do then the cops will give it back to you and the person who bought it will never ever ever get their money back.
lol stuff that
Hey tdawg, what's that last comment supposed to mean.. "lol stuff that"
It means if I bought the stolen engine thinking it was legit and I liked what I bought then found out later it was stolen off some guy I have never met, I would not give it back. Not because I am a bad person but because you would never get the cash back that you paid for it. Whats more important... You or someone else?
Tdawg, im sure the REAL owner of the engine is willing to pay the person to get the motor back man, i dont think hes just expecting someone to give the motor back and have them lose out on 1500$ ?
yeah, well "insane" won't be lol
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
