Someone hit my rear bumper on sat nite :-( on george street ....i need someone to fix it...i dnt care about the cost ...but i need a really perfect good job to be done....
Can anyone please suggest me good smash repairs?
Can someone also PM me the bad smash repairs where i shouldn't go?
I would really appreciate any comments...
Where is that Queen St Smash in revesby shonen?? Is it on some Queen St?? Do you recommend him???
Where is Sefton Smash Binky1970?? Any contact details of the above??
Manu
I havent seen an R34 with an M3 engine yet - could be interesting
Same thing happened to my car....except mine was ripped from the side of the rear bar..
some guy hit me while reversing out of the spot next to me.
anyways I went to Queen St Smash in revesby....faultless job and colour matched PERFECTLY.
and you're cars still Black????? oh my god!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
