well, offloading the seca, i was going to do an engine transplant soon, but another car came up, so i pounced on it and bought it :rofl: not a skyline but...
details as follow
1986 AW11 MR2 Supercharged
E51 Gearbox with LSD
Lowered 1" all round on KYB Shocks
Targa Roof
I take delivery of it next wednesday. went down to the shopfront to order some YAW11S black slimline plates, but they were taken ;) so i'm thinking YAW11M instead.
https://www.sau.com.au/forums/topic/64652-my-new-car/
  • Replies 44
Yeah nice ride, congrats matey!
If you haven't already seen them you might want to check out the High Octane DVD series, they do up an MR2 as a project car in a few of the earlier episodes - from memory it was a yellow turbo job that gets hi flowed, fat body kit etc.
Also has some interesting Skyline stuff as well, like a 326km speed run with a GTR on a narrow wet road out in the NZ boonies somewhere, and a GTS4 -> GTR project car.
PM me if you want to know where to hire em from as cheapo weekly rentals.... :)
https://www.sau.com.au/forums/topic/64652-my-new-car/#findComment-1212172
This car i'll be keeping until i finish uni and get into a full time job (two years atleast)
Car and engine are only at 115k kms, so nothing too huge. I'll have to go over the Dickson pits for rego, but it should be fine, has already been engineered for side intrusion bars and all that stuff.
Mods? Pod filter relocation first off, then exhaust and headers (no loud cannon this time :S), HKS/Cusco overdrive pulley kit, bigger TMIC.
There's a red AW11 MR2 in Sydney owned by a guy who works at UAS...ran a 10sec 1/4 a couple of years ago, he had 270rwkw or somethinig like that - i don't aim that high, but it won't be too hard or costly getting some good times.
Got some plans for her, the white wheels from my seca are going on too, same fit - cheering!
Money was paid today, forms will arrive friday, car to be freighted on monday, and arrives at my door wedsnesday, can't wait!
https://www.sau.com.au/forums/topic/64652-my-new-car/#findComment-1212546
