Lets have a big Ass cruise to the gong! 14/12/02 MEETING SPOT CHANGED!
  • Replies 122
Originally posted by Mr GTS
I Would like to come, but I need to know some more info abt the cruze, if something can let me know would be great!!
Pretty much meeting up around 10:30-11am at carpark 6C at homebushing cruising down to the gong via the nasho get some food and stuff down there and **** around abit then cruise back up :D
Originally posted by ultim8DTM5
ive organised a few barinas to come along (dates are the same, haha) so we are meeting up at 6C as well
:D
except we are meeting up pretty early, like 10ish
ive been informed that rumba is on the same day at the stadium...could make things a bit, ahem, packed?
rumba
hehehe
imagine all the 12yos you will be impressing
:band: :headbang: :rave:
Thanks Kabab.
Will try and get there, how many numbers so far?
kabab,
I might come for the first time but it all depends how long the engineer takes with my car, a drive to the gong would be good chance to run in the engine. By the way I take it that this is a am meet not pm???
Sorry Fellas - I'm out - No car. It's still in the Workshop - The ppl who were smoothing the inside of the plenum with that paste stuff haven't completed the work they were meant to. Everything else is OK tho. So should have my baby back on Monday.
Have fun ppl.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
