ummm.. i wonder whats gonna happen if u compair with same kw on both car??
and why compair HSV with NISSAN not with a NISMO??(e.g. NISMO 400R?)
anyway nice info u've provide... but i still like Skylines more than Holden... it just looks so much better...
cheers
  • Replies 350
k_hole
Registered User
Trader Rating: (0)
k-hole you sure you aint the reincarnation of skylinekiller or a buddy of sidewndr who have all joined on Feb 2005 just to have a look at how wrong all your comparison posts are.
and non of the holden or v8 supporters have answered my question about why do v8s need a 5.7L car with that much engine power to get a car to perform the same as a 2.6L car with 1/2 the power and its 10 years older.
The most enjoyable read ever was when they compared to R34 GTR to some New HSV in a speed mag i think. Both were equally modified (just a few small bolt-ons, boost and computer), and the T34 GTR beat the Holden in every aspect from rolling start to breaking etc... There is no argument that Holden has some catching up to do!
That was in Speed magazine I think yeah
The GT-R mauled the crap out of the GTS, and the GTS even broke some of it's drivetrain (I distinctly remember the 1 week old KAAZ LSD going snap)
But I'd have to say the most enjoyable read of the kind I've ever had was in Wheels magazine in 2002 I think, R34 GT-R V-Spec 2 Nur vs HSV V2 Coupe GTS
both dead stock
The Skyline pulled the Gen3 out the Monaro's arse
and I loved every word of it.
Maybe Skylinekiller should go read that article.
Thats easy, because GM can use light utility/truck engine as the basis of a performance engine to get cheap, reliable/durable performance. Throw in some alloy casting and the thing actually doesnt hurt sitting up the front of a sports car/sedan.
The V8 saves the hassle and complexity of turbocharges adding weight and heat, extra cooling / packaging requirements, adding to service intervals of the car etc etc.
And as for fuel economy etc etc. Think about it, if you put your boot into either, they both suck gas. Power is a result of flow thru the engine, and in turn the more power you make the more air you consume and accordingly the more fuel you need to use.
If you want to compare sports car to sports car, not sports sedan, compare the performance to a Corvette, an Ultima, a Robnell Cobra a TVR Cerbera. Lotus Espirit GT or another V8 powered Coupe/Sports car.:rofl: ...You start to realise that V8 powered sports cars are an expensive breed, even 2nd hand with the exception perhaps of a 928GTS
I cant believe this thread is still going...a think some Nissan drivers have blinkers just as big as Holden drivers:(
..and credit to Nissan the R32 GTR, they out foxed everyone in the old Grp A days. Holden were homolgating an ordinary sedan, Ford a shopping trolley, BMW a mass production rwd NA 4cylinder and Nissan go and BUILD a twin turbo, 4WD car from scratch to make the most of the rules and the class. They did the best job, but they did it with a blank canvas that was the R32 series, everyone else was throwing fibregalss and turbos/throttle bodies at road cars.
If you look at the job Nissan was doing with the DR30 and the R31 in the GrpA days, it just highlights the huge leap they took with the R32:thumbsup:
Thsi debate always ends in arguments, lol, i think thats why they are started, its as bad as talkign about who's girlfriend is better looking:)
all i'm saying is that this is a gimmick and its pretty funny
people like Roy have made some good posts so its not all a loss
why does nissan need 2.6L and mazda only need 1.3L then
just curious, ur arguing a point that makes u look even worse.
if you put a 1.3l next to a 2.6l and debate it all you like,
but then if i put the 1.3l mazda next to a 5l+ engine and compare the two it would make you look worse off, so you were better of not replying to anything
besides thats like comapring apples with oranges, pointless
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
