agreed GMB....they should ban extremely small penises like urs!
:) OK
It would be funny if it didn't come from a guy that is 20+ and can still get into the movies as a child.
You can insult me when you are over 5'5" and not a second sooner wee man :)
f**k u.
i save more money than u that means
also its my birthday today.
happy birthday to me.
Sweet 16 at last ;)
Happy birthday darlin.
Now you can sit at the big kids table at McDonalds (its ok we will let you use the high chair still so you can see)
You would save money if you would stop making those midget porno's that you have to film/direct/star in ;)
  • 1 month later...
  • 1 month later...
