humm beeerrrrr,
glad it's friday, going out for lunch with work, and plenty off bbeeeerrrrr
Man you have it tough.
Your on the net all farking day looking at SAU and other crap, you go out for lunch and get slaughtered.
Do you actually do anything at all that resembles work in that overpriced job of yours!!!!
:D
:D
humm lets see
thinking
thinking
ORDER more beer
thinking
talk long distance to mates in Perth
hummm
buy some more shit i don't need for the car of eBay
still thinking
nope
u?
Edited by WogsRus
humm lets see
thinking
thinking
ORDER more beer
thinking
hummm
still thinking
nope
u?
You sure are a KENT
That is all
waiting for pizza now.. then I have a meeting @ 11 :wave:
Well i've been at home getting hammered the whole time waiting for 11:30 to roll around to head out on the town :O
And here i was thinking i had it tough :)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
