  • Replies 115
If anyone wants some nice trick alloy bonnet pins that sit flush or 1mm above the bonnet line then let me know. Saw some neat ones at the Motorsport show the other day, skyline_geoff bought some at the Trade Store, im getting mine next week for my new bonnet
I don't need any at this time, but I might in the near future :)
Can you get a business card or details of the distributor when you go get yours please?
Pics would be good too :)
Yhe i have the business card at home. They are actually in NSW, if Geoff sees this he may post some pics. The bottom half that gopes into you radiator support mount is the same as usual, but rather then a pin thru the boonet, you have an aluminium housing the size of a gum leaf that has a push type latch/door.
When you push the latch, it releases the pin and allows you to open the bonnet. To close you clip it back down and its all spring loaded. So sits all neat and flush on the bonnet. Could even be colour coded i guess. They are attached to the bonnet by approx 6 allean head cap screws.
They are advertised in Autosport Engineering and are trick units. Ill check, but im 99% sure they are FIA etc approved so a re well engineered and perfectly safe. When i get back to Melb from Adelaide ill post the details up in the Motorsport section of the forum
what does compression have to do with pinging?
The higher the compression you run, the lower the detonation threshold. i.e. The less boost you can run before you'll start running into detonation problems.
I have never heard ANY tuner who knows his conrod from his clutch say that they can't run more than 13.5psi boost with a stock engine because the compression is too high.
I ran 1.2 bar (17.5psi) on my old GTS-t (I didn't want to run more because it was my daily driver and I didn't want to push the engine too much) and it made 280rwkw. The new owner ran it upto 1.5 bar (21.5 psi) also on the stock engine, and stock compression.
13.5psi = too much? :confused: Sounds like tuner limitation, not compression limitation to me :Oops:
when it hit around 15psi i can hear it ping, thats got really nothing to do with the tuner, i wanted it to be very safe cause i used to use it as a day to day car but now its purely for racing and the od cruize. i got more mods to do soon so we will see.
Oops, Speed.
I guess neither of them would like me confusing the two. Its too late and i had way to much C++...
They don't mind. Both Speed and Wheels are owned by the same publisher. If you confused any of those with Hot4's, or FastFours there would be hell to pay :D lol
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
