just doesn't do it for me, ey...
don't know why. not a fan of such a sleek car having big cumbersome wheels and a comfy, laz-y-boy style interior... just think they're better suited to looking fast etc...
once again, just my $0.02
Originally posted by BY BY
looks very sexy.... seen photos somewhere... i think ryan might have a few...
19 inch chrome dronnels by the look of it. It arraived on Friday night on a trailer.
Beautiful S15.
hey man
so it looks nice ?
i havent and didnt see it at the show
i went thru ryans pics the onez he posted but i didnt see it there either.
BTW saw ur car look very very sweet i was gonna say hello but i coudlnt see ya around it :burnout:
im lookin for pics too, only saw the one in ryans pics and somehow walked past it without noticing it at auto salon even though i was told to look for it?!
that thing is sex on wheels, some of you guys have no taste at all.
i cant wait to get my cream leather interior done just so i can be just like him and half the habibs in sydney, who cares if they've all done it, its coz they have good taste. :)
and those rims are porrrrrrrrrrrrrrrrno.
someone find picssssssssssssss.
exactly how I feel too
Originally posted by PranK
HURL-AGE...
like tan leather hasn't been done 10 billion times before - i'm not a fan.
Funny, I was thinking the same about those horrid wheels you wanted for the 180 :uh-huh:
I didn't see it i don't think. Must've walked right past it. Then again i didn't exactly take my time at Final Battle - was in and out pretty fast :D SXT-00C or whatever it was, the Silver S15 with Veilside kit looks hoT!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
