Oh yeah guys, just to let you know, this little prick was flogging off cheap shit copies of Diesel jeans on ebay. I have 2 real pairs of Diesel's, and let me tell you, these ones he is selling are an absolute disgrace. He is raking in $60-$70 a pair for them too, often more.
Just reinforces the scamming nature of this bloke. He wouldn't even refund my cash, but instead insisted on giving me a couple of "Genuine Von Dutch hats", all of which were fake as well.
It's people like this who ruin it for everyone! ;)
EDIT - The address info you have for him is current. Mucubbin drive or whatever in VIC. All the Victorians on this board take note :rofl:
  • Replies 72
ahh mother fcuker....
just found out he sold my gauges, timer, gear knob and sed that the docks stole it!
also tried to sell my coilovers, and kaaz lsd
mother fcuker charged me 300 for a bonnet that costed him 175 to replace
im sure theres plenty more stuff that i have yet to find out
i'll get him one day
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
