taking the MR2 through dickson pits this week, just wanted to ask a few questions
my car doesn't have the tyre placard, do i have to find one off another MR2 or...
also my spare tyre doesn't have the 80kmph limit on it...
any help?
oh, and whats the rule regarding high mount break lights?
mark?
i'm REALLY stressing about this, as rego ends 3 of march...thursday
https://www.sau.com.au/forums/topic/65905-my-turn-through-dickson/
any help?
mark?
You'll probably need a tyre placard. Someone I know printed one out on a sticker you use for mail or similar and stuck it on (you need to get a scan or something of an original one)
Your spare would have an 80kmp/h sticker on it if it's been engineered. Has this car been registered before?
High mount brake lights are required on post 86 cars (from memory) if you don't have one, you can buy one from clints/the warehouse and stick it on your rear window. Wire it into your exisiting brakes (not too hard at all).
i've got a tyre placard, but it's in japanese, but i hope that'll do
the spare tyre doesn't have the 80kmph sticker anywhere, which is surprising.
car HAS been engineered to the ADR, and has been registered in sydney.
is the 80kmph sticker available from tyre stores?
A japanese tyre placard is not acceptable at Dickson. I got absolutely reamed for this. I got one off an aus delivered GTR (brand new from Nissan) and they still failed it saying it was JDM model and needed the appropriate placard from either the original compliancer (who is now out of business - was complianced back in 1999) or from an engineer. So in the end I had to get the wheels engineered (the engineer also gives you the spare tyre max speed sticker, although dickson didnt check mine).
Have you got the engineering certificate? It might have the appropriate modifications in place, but it -needs- to be engineered or Dickson wont even look at the car.
Good luck :(
I think you might be able to avoid going to dickson.
if the car is more than 10 years old, you dont have to take it to dickson. i don't know why, but thats what happened with me. my car is a 93', and was registered in NSW. i just took it down to my friend who does rego checks and he passed it on the spot. changed over to ACT rego no problem. same with my last car too.
you should be able to just take it to anywhere that does inspections and it shouldn't be a problem.
or maybe i'm just lucky.......
i needed the right placard and the 80kmh markings.
from memory, we used a permanent marker to write 80 kmh on both the rim and the tyre on both sides (nice and neat like).
correct tyre placard i had to get from the compliancer (ugh).
good luck mate!!!! :)
the more stories i hear the more i think i had it easy despite getting annoyed with them. when i was their the only things they checked were my lights low and high beams. break lights., reverse light, they checked my engine bay numbers had a quick look underneath and did the hand brake test. they didnt evne look at the place car on the 80km thing.
this is all strange....I got my car from nsw and it's an 89 model, all I did was get rego inspection from tez then went to a government shopfront and it was done. I do have the engineers certificate though so maybe that's all you need :confused:
i agree. same happened to me with a newer car! i'd try and avoid dickson if you can. its worth a shot anyway.
My bad, I completely missed the part where its already registered.
If its already rego'd you can do as mentioned above (roadworthy and shopfront) if its not rego'd or only on temp rego, it will need to go over dickson.
Yeah dude you dont need to go to dickson and nobody else will notice any of that!
HOWEVER!!! I went and had my rego done at a workshop and then realised I needed to go to dickson for a VID check (as the car was coming in from NSW) When I went in for the VID check they Defected me...
Try to avoid that! Do the VID check first, if you need one... I think you do.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
