Time for another Thursday night fun run..
Meet Time: 8pm
Meet Spot: Carpark opposite Grand Hotel (Map 19, E20)
Leave: 8:30pm
Ok, meet spot is no longer BWCP, but about 5-10mins north. It's in the carpark opposite the Grand Hotel, Biggera Waters. There is a playground there just fronting the waterway, and it's just in front of a large seafood restraunt (you can't miss it). NOT the boat ramp carpark
First leg is a casual drive down to Tugan, and then back along the highway of around 60mins. This will be followed by another meet. Those that wish to go on the "extra extended tour" (which may be a late one and will involve spirited driving) may choose to do so, or meet back at where we started around 10pm. Further details will be provided on the night.
This is not an official SAU meeting, I am not responsbile for anything that happens during the course of this adventure, etc, etc
If anybody wants any further details on what I am thinking for the night, please PM. If I don't reply, please don't be offended, as I will only provide further details to those I know personally or roughly enough, for obvious reasons.
Cheers,
https://www.sau.com.au/forums/topic/65908-thurs-march-3rd/
ok.. did a scout around and bit of a test run last night.. got a good little route which is hell fun..
meet spot is also getting changed to opposite the Grand Hotel as no point sticking to BWCP.. There is a carpark there in front of a Seafood place which can hold a few cars.
https://www.sau.com.au/forums/topic/65908-thurs-march-3rd/#findComment-1233330
