  • Replies 288
I might be interested later this year, if this offer still exists then. Haven't done any research into turbos though yet. I'd be looking at something good for a R34 GTT Auto. Something thats a good streetable turbo IE don't have to wait till 5000rpm till it makes good boost. Maybe even hiflo stock GTT turbo, not sure how this responds compared to stock 32/33 turbos but they are larger apparently.
You don't need to do any research.
These are the questions I need answered:
How much horsepower/kilowatts do you want? eg. 300rwhp/210rwkw or engine hp/kw
What are you using the car for? eg. Street/Drag or just Street or just Drag
When do you want boost roughly? eg. 2200/2500 or 2500/3000 or later
Do you want power early or late in the rev range?
What Mods you engine has or is going to have including computers or exhaust etc.?
Obviously, what car?
Intercooled? and is it large, small, medium?
Still running AFM or upgraded or no longer there?
Custom exhaust manifold or standard? (custom exhaust manifolds give you more options)
External wastegate or internal(limited to virtually 450hp)?
With this information I can give you a range of turbo's or just one that will suit your requirements. The more picky you are, the less range. eg:
if you want big horsepower: 5 or 6 decent turbos will suit
if you want big horsepower but want it smooth delivery at 3000rpm then it narrows it down to probably only one. There is a turbo to suit every request and any turbo can be modified to suit your needs.
So you give me info, I'll tell you what turbo/turbos will suit and you can do some homework on what I have given you and decide what you want.
How does that sound?
Answers:
RWKW? Enough to have a bit of fun on occasional track days.
90% street use
Boost @ 2500 rpm on but not dying above 6k
Early or late in range.. best average power from 2500 up
Stock standard R34GTT auto.
Thats why I said later on cos I'll need time to put on Full zorst, FMIC, EBC,
Fuel pump etc.
Internally gated sounds fine for what I want.
I expect <=250rwkw to be plenty for me.
Main issues for me are reliability and streetability/response.
Answers:
90% street use
Fuel pump etc.
You will probably be looking for something like what I am getting.
rated at 450hp, ball bearing. Easily capable of handling 300rwkw. Plus boost will come on full at around 2200-2600 depending on what level you wanna run. But should be able to get around 16psi at 2300rpm. And it will hold it through 9000rpm. Would cost you around $1700
i will answer questions for him as best i can:
As much HP for a tiny budget - doesn't have to be real crazy
Street use mainly
Boost aroun 2500-3k
Power Early in revs
blitz FMIC/3" exhaust, POD, boost controller
R33 series 1
Big BLITZ FMIC
Stock ECU/AFM setup
Custom dumps - 3" cat back
Main thing right now is he wants one that is almost exactly the same as stock 33 one - so just bolt on, attach current lines and away he drives..
No real budget right now - get me some prices on cheaper ones and expensive ones too - around the 1k mark
Not after massive power figures - just bigger than stock :D
Something to handle 450hp would be the same as above mentioned. $1700.
It doesn't really have a model number as such. It does but it is a custom made job by Garrett themselves. They make them to order.
If he just wants to hi-flow his one it will probably still set him back around $1300 depending on how bad he has damaged it.
All of these turbo's will bolt straight up to 33 manifold.
As I said before. The above mentioned turbo is a Garrett GT450hp ball bearing turbo. I can probably get something slightly smaller for around $1600 but they don't get much cheaper than that. Especially for BRAND NEW.
G'day Daniel,
I'm looking for a twin setup for my R33 GTR, along the lines or equivalent to 2530's.
What turbo's would you advise and how much?
The car is fairly stock, cat back, pods, and about to insatall a Power FC.
Then you will need the Garrett GT2530 twins rated at 500hp. As I said in the pm, they are available at 600hp and 700hp ratings also but this would not work effectively on yours.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
