well as long as the flange is the right size i think we can deal with doing some braded line work
what kind of PSI are we talking about insode the oil/water lines?
also i don't know much about turbo's mate - when you say 0.82 A/R that means?
as long as it bolts on fine - i'm confident we can get the line work done
  • Replies 288
Cool, I'll find out what I can
The water lines are only gonna be around 15-17 PSI.
The oil lines I think are only feed. I don't know if they are under pressure, if they are...it will be engine oil pressure.
between 20-60 PSI depending on revs.
'A/R is the ratio of the exhaust housing refering to the size and shape of the scroll that is cast into the housing. It determines how restrictive the housing will be, versus how quickly the turbine will spin up. A lower A/R ratio results in a more restrictive housing. This restriction speeds up the exhaust gasses and increases the amount that the gasses will expand. It's the speed and expansion of the gasses that causes the turbine to spin. So with a low A/R ratio, the turbine will spin up quicker, but as engine output and rpms increase, the restriction of the housing begins to build up too much back pressure on the engine, which reduces performance. A good rule of thumb for when there is too much back pressure is when the pressure in the exhaust manifold is more than half of the pressure in the cylinder. So basically, a larger A/R ratio will improve your engine's top end, while losing some mid range power and increasing turbo lag. A smaller A/R ratio will help the bottom and mid-range, but may effect the top end.'
0.82 is a large size.
0.60 - 0.80 is usually good for the mid range stuff edging towards top end power. When they start going over 1 is when you get large amounts of lag. But you would compensate for this by using a Ball bearing turbo which helps to counter the lag effect. You can successfully eliminate extra lag by choosing the correct combination.
has anyone recieved any turbos from this guys and have any comments about them?
Thanks. I'm looknig for a turbo to buy right now.
probably 450hp - 500hp, T3 Flange, with a .63ar Exhaust housing.
I don't like your chances of being able to get anything rated to that hp with a 0.63A/R. I'll do my best.
Is there any reason for wanting the 0.63A/R?
You are really limited in your choices for the T3 flange also.
You would probably have to go with something like what I described above.
A T04 with a V1 compressor trim and the P turbine trim with a 0.82 A/R to achieve those hp ratings.
You might be able to play with a few options on the T3 housing to squeeze a little more out of it but I'll have to check with the supplier to make sure.
I'll see if they can do a 0.63A/R T3 flange on a turbo rated at 450hp. If not, have you considered going for something like a twin ball bearing GT25 or something that will be better suited?
You could also wait a couple of months as Garrett is bringing out some more designs in the T3 configuration. So then you would be able to get a GT25 440hp with a T3 flange. Now wouldn't that be nice.
Hi Daniel and thanks for the turbo price, would recomend these turbos to all sua members as I have seen the quailty of the work.
No worries mate. Glad I could help. My other supplier has been really slack with those gaskets so I am going to try direct with ACL tomorrow hopefully. It's been two weeks and all they say is....oh, we haven't had time to ring. Bullcrap! I even reminded them twice. I might also try coventry or someone else like that. Anyway...I'll let you know how I go.
hi daniel, just wondering what a turbo off a HR31 silver top motor is, and how much 1 would cost??
MY BAD!!!!! i ask in the forced induction section about this and the silver top rb20 motor only came out in the R32 gtst. doh! anyway, its for a mate he has a toyota sprinter with a 4agze turbo conversion and he needs a new turbo bcoz his one is blown, the turbo he has on it was off a rb20 silvertop but he told me they were out of a HR31 obviously he got mixed up. So i remembered this post so i though id try and get a price for him and see if hes keen. ok. thanx again for ya help with it. looking on google atm. will post again if i find out what type it is ok. i was told it could be a T25BB but not 100% sure. 4 bolt flange.
Definately not a BB. That would mean it is a ball bearing. The only skyline I think is the 34 which has the bb turbo. As for the silver top turbo, I have a blown one which I could have fixed for you. I would want $1100 with it fixed. It is a hi-flow and has supported me to roughly 215 RWKW. If you want a 360 degree thrust put in, then I think it will be slightly dearer but not much. Let me know if he is interested. When it is fixed, the only parts that won't be brand new will be the exhaust and compressor housings. The rest including wheels, shaft and cartridge will all be brand new.
Are any details available about the new T3 flange options ? The aftermarket is crying out for things like a T3 flanged .86AR housing for the NS111 turbine (GT2530 , GT28RS etc) . We also badly need some integral gate GT30 and GT35 T3 flange housings .
Thanks A .
Discopotato03: My supplier has told me a couple of months. But we all know how accurate that could be. Companies like Garrett can say 2 months but it will take them 3 or 4. All I can say is they are on their way and they aren't too far off now.
Gatty: I have been told that he will not just do the seals. All turbo's that come through him are to have a full service kit and balanced. The reason for this is quality of workmanship. He is the best I know and his work is proof of that. He said it will set you back around $550 as long as there is no other problems with turbines or housings.
Pentae: Sorry but that info is privileged. All I can say is that he is an authorised Garrett dealer. The turbos are all brand new. You won't be able to achieve cheaper prices without going through me. If you can get a cheaper price elsewhere, AND CAN PROOVE IT, then I will TRY to beat it.
The other thing I would like to note is that if you live on the Gold or sunshine coasts or in Brisbane/Ipswich or somewhere local to brisbane then I will deliver the turbo in person. And I can arrange a COD if you feel untrusting.
Got a quote tonight to do the braided lines.
Both water lines and the oil supply line including fittings, bolts and washers all custom made.....$100-$120
He shoots....he scores! I am really happy with the amount of service I have been getting from our local businesses. This guy finished work at 5 and drove out to my place to look at what I needed to do the job. Not many people are willing to do this these days.
Therefore, a big praise and plug goes out to Bayside Hose and Fittings. 07-3286 9354 They are located in Shore street Cleveland. 20 years in the industry.
Hey mate.
Just curious as to why you say the High Flow's are only 300hp when GCG and a few other places all quote there turbos at 450hp?
Just did a bit of a serch and a lot of people are getting 230-250rwkw's out of there high flows... Sydney Kid being the exception with 264kw
Also Does it matter if I get a R32 turbo highflowed instead of a R33 one (if cost is a huge difference between the two)?
as I will be buying a 2nd hand turbo and getting that done so I can bolt it on when I have all of my parts ready to go.
I am looking to upgrade the turbo in the next month or so. Just waiting on the bank balance to rise just a touch more.
Thanks mate
How much horsepower/kilowatts do you want? 230rwkw
What are you using the car for? eg. Street/drag
When do you want boost roughly? coming on from 2200...full @ 4000
Do you want power early or late in the rev range? mid-late - i dont mind a Little lag if if will give a better top end hit...must last to redline
What Mods you engine has or is going to have including computers or exhaust etc.? zorst, intake, FMIC, fuelpump, injectors, probably a power fc, possibly cams
Obviously, what car? S13 with a RB20DET
Intercooled? and is it large, small, medium? medium at his stage....VR4 cooler - apprantly flows enough for 230rwkw
Still running AFM or upgraded or no longer there? stock Rb20 80mm AFM
Custom exhaust manifold or standard? (custom exhaust manifolds give you more options) stock manifold - as below....preffered stock but non stock if price is right
External wastegate or internal(limited to virtually 450hp - internal gate preferred but external if price is right
thx jason ;)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
