i'd like to issue you with a hearty "Ahoy Hoy" im the local Metrosexual/simpsons freak/pink shirt wearing/flamboyant/lovable/cute one.
im sure you'll fit right in with us, as long as you can poke fun at yourself and enjoy making fun of others that are different lol.
i can smoke in your car, you smoke can smoke in your car!!!!!
if anybody wants to talk about drift, this is your man. :wassup:
i'll never forget the time when james drifted around the roundabout on isabella dr, near chisholm, TWICE in one go!! two complete circles, in traffic! i was impressed and sh*ting myself at the same time. :rofl:
Police and dickson inspectors -do- read these forums... just keep that in mind, and please keep the negligent driving for the track. I value my car and life.
oh lay off, Jester was'nt bragging about it, frink was.
Dont do what donny dont does, Dangerous driving is bad, dont drive dangerously and drive safe, purple monkey dishwasher.
Oh you can talk andrew leaving a certin place on a certin night. I cant comment we all do it once and a while.
hmmm
'contemplates removing his avatar'
There is a time and place for this but sometimes ya get the itch to do it and well lets face it, a blokes gotta do what a blokes gotta do.
Still would have been choice to see lol
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
