overboost for good sql you should have a strong front stage... it would be a bad idea to run the front off the deck and back amped... it just means when you turn it up you will get distortion through the fronts ...
id rather have amped front speakers and no back speakers
and yeah it would be intersting to see the thd stats on that pyle amp and the continuous output figures.....
I have Splits, 2 Subs, 4 amps etc etc etc .. but not everyone has that kind of money to spend on a system .. if he put some nice 3ways in the front and some coaxles or 6x9's in the rear he should be happy ..
hang on, so you're suggesting he buy new gear to replace the stuff that isn't working right???? seems illogical to me.
kill hsv, its just a matter of tracking down your problems with your tweets. i wouldn't be replacing a set of splits with "3-way's" and i'd rather poke myself in the eye than fit 6x9's.
you've got the right bits, just make them all talk to each other and they'll be just fine. you'll find that the separate component route (i.e. splits) will be a far better block upon which to build, should you want to upgrade and change things in the future.
and in regard to rear speakers, you'll find many "sq" systems run no rear speakers at all. pardon the cliche'd phrase from the audio world, but you don't go to a live gig and hear the performers from behind you. rear fill is best left to providing rear-seat passengers with music and multichannel surround systems imo. if you want to run rears, cross them over high (really high) so as to avoid pulling your soundstage backwards and try to fade them out as much as realistically possible.
cheers
d
overboost, I don't suppose you have the specs to that Pyle amp anywhere do you? I'd like to have a look over them if I may. :D
500 Watts X 4 Output
1000W x 2 Bridged Output (500 x 2 + 1000 x 1)
Dual Variable Hi/Lo Electronic Crossover Network
Dual Variable Bass Boost (0 - +18dB @ 60Hz)
Variable Input Level (Gain) Control
Remote Turn On/Off
Gold Plated RCA Inputs
High Level Molex Input
Power On LED Indicator
LED Protection Indicator
Blue LED Scanning Illumination
Remote Bass Boost
S/N Ratio: > 95dB
THD: < 0.04%
Thermal Protection
Overload Protection
Short Circuit Protection
Anti-thump Turn-on
Tri-Mode Configurable
Dimensions:10.87''X2.26''X17'' (WxHxL)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
