Hi All,
I have two questions regarding powerfc for rb25det.
1) Does anyone have a value for the Air-Temp on the powerfc for rb25det. Mine shows --- and has never worked. Is this normal or am I missing a wire somewhere? Does anyone have this working or know how to get it working? I've noticed theres a "PowerFC Temperature Sensor Harness" available from greeline but no actual sensor? I emailed them and never got a response
2) My idle seems to be higher than what the powerfc is set to. Currently my powerfc is on 740 for both AC Idle and FC Idle. My idle is normally 850 ish. The other options for Idle are at 1100 and 1000. Even if I set all Idle's to 1000 it never seems to honour it and just runs it at 850ish all the time. I've noticed under monitor my water temp is always 78. It hardly ever goes above 80. Even hard runs on 35deg days its always 78, very rarely even 79deg. When I check out water temp correction theres a break point for 80deg and one for 50deg. Because my water-temp never hits 80deg the powerfc would be honouring the +50deg correction. I've noticed this is like 1.05 instead of 1.00 for 80deg. Would this result in advanced idle? What else would the correction of 1.05 affect? Or does the powerfc apply that 1.05 correction to all maps because the engine water is colder so it has to add more fuel, spark, timing, ignition or is the correction just for fuel as an example? I don't remember the exact correction valve so it may not be 1.05 I'm pretty sure its around there. Just wondering if I should set the 50deg correction to the same as the 80deg as my car never hits 80deg
*** PowerFC software now commercial? ***
APEX FC commander PRO Software has just come available. The software for the Power FC has always been very ellusive to obtain. The expense if you could get it was said to have cost Thousands of dollars. Now you can buy the software just like EXCEL DEALER uses to tune your car.
The software is compatable with OS windows98,ME,2000 and XP.
Only the Hand commander 415 X001 is suitable with the software. The H/C 415-N001 is not suitable.
$543 delivered http://www.nengun.com
https://www.sau.com.au/forums/topic/66422-powerfc-rb25det-questions/
It affects idle and if its too rich/lean you will get hunting, on 2 different car's with both PFC i've seen by making adjustments to the water temp correction
Idle Go up - With adding more fuel 80º - 1.10
Hunting @ idle 80º - 1.00
This depends on the fuel map's tune if its tuned lean enough on the map to get hunting on idle I found that by making adjustments up stops this hunting - 80º, Over rich tune on the fuel map at idle with give you low idle by adjusting it down for 80º this improves the idle.
80º = And example as this depends on what you'r operating sits on.
Q1)
The GTS-T don't come with a Inlet temp sensor unfortunatly only the GTR does :)
temp sensor)
Thanks for reply. Yeah i thought it was GTR option only. Im wondering if it can be made to work by either getting the GTR sensor or getting a 3rd party sensor (as long as it returned the same signal). Thanks for your help/advice I will try and work out a temp sensor hookup. Would it by a special type of sensor for the temp or they're like a universal one from like jaycar or something>?
water temp)
My idle is never what the commander is set to and I noticed my water was always just below 80 so it was using a correction of 1.10 and 1.15 whereas for 80deg its 1.00 1.00 for both. I was sure it only affected settings to "warm" the engine up as such and may affect idle. I have seen slighty better results now with 1.00 correction for the 50deg value as my water temp never gets to 80, its always 1 or 2deg below. However I am now experiencing idle hunt since i've made that change, one time it went as low as 650rpm and was at stall point. The idle hunt isn't all the time and appears to be a bit erractic. The powerfc I think tries to correct it and change the idle rate too quickly (at least my educated guess). I wasn't really trying to solve anything just noticed I never got to 80deg and remember the water temp page had settings for 50deg and higher, then another for 80deg. I then realised that Im never getting to that 80deg value cos im always just below it.
nah just the stock thermostat. i hardly ever see 80deg. anyway ive set both to 1.00 correction. wire 36 on the rb26 goes to the gtr temp sensor. wire 36 on the rb25 loom goes nowhere (according to several diagrams ive checked). any ideas on if i could get a standard air temp sensor and use it or is there a generic type or i could get a 2nd hand gtr item i guess and try it. my only concern was on the rb25 wiring diagram i found wire 36 or at least pin out 36 goes to "FICD" realy. Anyone know what this is or if its an incorrect diagram as the writing is hard to read. the diagram is r33english.jpg
My best suggestion is to have a look on your own car, it only takes a couple of minutes to remove the kick panel. On the Stagea, it has no wire in #36 on the connector.:)
hi sk and others,
i had a look i have a wire in pin 36 but nothing in 35 34 and 37
34 35 37 on the rb26 ecu goto the 2nd afm, 2nd oxygen sensor and one of the other sensors associated with the twin inlet system on the gtr. pin 36 on the rb26 is the temp sensor. my theory was the powerfc will try and read it regardless as the hand controller is displaying it but just as ----. so my hope was the ecr33 powerfc still had the code and logic present just no sensor. pin36 i mean by looking at the ecu whilst it is bolted in and connected, 6th pin on left side from middle. its a light grey wire but i have no idea where it goes. what year is your stagea sk and is it a series 2 rb25 ? wire 36 according to the wiring diagram is the ficd (fast idle control device)
Ooooops sorry, I should have mentioned that the Stagea has R34 ECU pin outs. And #36 is certainly blank.
With the Datalogit I can see the correction table for air temperature on the Power FC RB25DET settings. This is the same as on the RB20DET settings and it certainly works, I have the GTR top end on the RB31 and it uses the standard R32GTR air temp sensor. I just ran a wire to the blank spot on the ecu connector. I couldn't see the correction table on the Commander though, but the Datalogit has no such problem.
Can you see the air temp correction table on the R33 GTST Commander?
No problems. Well I have ecr33 powerfc the new model that came with hand controller from nengun. The hand controller under Monitor shows
InjDuty
IgnTmng
AirFlow
Eng Rev
Speed
Boost
Knock
WtrTemp
AirTemp
BatVolt
Under setting I have
Ign Map
Inj Map
AirFlow
Injector
Boost
Acceler.
Ign/Inj
Cranking
Wtr Temp
Rev/Idle
If I choose to monitor AirTemp its always ----- deg.
I know the GTR plenum has an intake air temp sensor. I have the RB25 plenum and i was hoping to get a stock thermisotr from jaycar and use that and feed its signal to wire 36 and hope the powerfc would just display the value. Then I wouldnt need a seperate temp sensor (which is no problem $20 from jaycar) would have been handy as the value was in the same spot as the other stuff, even if the temp sensor was in the airbox etc and not neccessarily on the plenum
On the Datalogit (for all 7 of the RB25DET PFC software versions) the air temp correction table is on the same page as the water temp correction table. I get readings and the correction table functions on the RB20DET Power FC.;)
Ok in the FCEdit software yeah the temp settings are on Settings 2 Inj Vs Air Temp.
I have the software but no cable or connector. My Powerfc hand controller doesnt have any of those settings (for air temp) under Setting. My WaterTemp table in the hand controller on has water temp settings. What happens on one of your rb25det's if you choose Monitor, 1 Channel and choose Air Temp. Do you get a value? If so what ecu are you using and where is the value coming from?
I dont want to control the inj settings based on air temp, i merely only want to display a value under Monitor so I can easily see what air temp intake is or airbox temp is without buying an external sensor
Hi SK,
Did you get a chance to check under Monitor on one of your rb25's. I know its a long shot but would love to have the AirTemp working, plus a few other members would love to see if theres a way to get it working
Hi SK,
I like that "one of your rb25's" , at the moment I only have 1 X RB25 and that's in the Stagea. It's an auto, so no Power FC in it (unfortunately). Let me reinterate what I know from previous practical experience;
I have used a GTR inlet air temp sensor on an R32GTST Power FC. I used the GTR air temp sensor because I figured it woudl be the right range and resistance ramp to give accurate temperatures. I had to run one extra wire as there was no provision in the wiring harness for an air temp sensor. I connected it to #36 on the R32GTST ECU plug. I can program the air temp correction table with the Datalogit, and I can log the temperatures. On the Commander, in Monitor mode, when I select Air Temp I can see the readings.
On an R33GST Power FC (all 7 software versions), I can program the air temp correction table with the Datalogit. The initialised settings on the Power FC have no air temp correstion ie; they are all set at 100. This is the same as R34GTT, R32GTR, R33GTR and R32GTST.
So, I see no reason to believe that the R33GTST Commander would read any different (it is the same Commander as most Nissans). It will only take a few minutes to connect one wire and test it. You don't have to buy an air temp sensor, parrallel it up to the water temp sensor. The range is similar, it may not read accurately but at least you will know that it works.
If you do get it working, then I would suggest using the air temp correction table, it is a good feature.
Hope that is of some help.:)
hey sk,
sorry i thought you access to a few rb25s with powerfcs, sorry for assuming. I still want to continue and get this working just no idea where i can connnect to the temp sensor too as wire 36 is connected and according to the diagram its ficd relay
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
