I have a white "TRUST" sticker that's a tad over 30cm long that I bought in Japan in January and am considering putting it on my car. Only thing is, the only trust component on my car is the replacement filter in my airbox. Now should I??? or shouldn't I??? I want to put it on but just not sure............... I haven't always been the biggest fan of putting stickers on my car when I don't have anything significant from that particular company on my car. What do you guys think??? and where???? cause the top section of my windscreen is reserved for the Impact sticker to come................ hmmmmmmmmmmmmmmmm decisions decisions
https://www.sau.com.au/forums/topic/6651-opinion-wanted/
Originally posted by Nismo_Freak
tisk tisk ... NOOB! ... only YELLOW stickers add hp ... other stickers add torque.
yes, yes, your right. :D
Don't forget to remove one of the wiper blades. This impoves aerodynamic efficency.
https://www.sau.com.au/forums/topic/6651-opinion-wanted/#findComment-98894
Originally posted by Silver-Arrowz
Rule 1. Stickers add HP.
Rule 2. Neon lights have a 20hp value.
Dont forget it's imperative you remove the cat-back exhaust and just leave a phat muffler. This, combined with the stickers and the neons, will see you at least into the 11s :bahaha:
https://www.sau.com.au/forums/topic/6651-opinion-wanted/#findComment-99217
Guest GR33DyMANGO
... and now for some empirical evidence.
i used to own a bitsamissing prancer (how embarrasing:( ) .. anyway.. i did the following mods and reaped amazing gains:
1) i placed a ralliart sticker on my front windscreen - instantly my handling was better.. i couldnt believe it.. and i took 5 seconds off my quarter mile time of 19hrs and 20 seconds. wow.. i was truely impressed...
2) i took the muffler off and put on some try hard non- sports exhaust. - wow.. again i couldnt believe it. my launches were now amazing.. i dragged a ferrari and beat i by about 100 car lengths (if only that car wasnt parked on the side of the road!)
3) i painted the windscreen wipers white.. oh my god! this made my car wipers move really really fast... plus it made chicks stare in awe at how kewl i now was.
4) a added an LED rear brake light to my rear window. now this was really worth the dosh.. u wouldnt believe how much better my brakes were. my braking distance reduced from 120 metres to only 60 metres.. it was truely amazing.. apologies to little timmy and his red bicycle for that unfortunately little hitty hit hit#.
just look... now these are REAL performance gains. u guys talk about your (hahaa...) fmic's, fancy sports exhausts... and for what??? all u need is a few stickers, a can of paint and an LED rear brake light !!!
#= actual event was created during period of slight delusion, rather know as being diagnosed clinically insane.
https://www.sau.com.au/forums/topic/6651-opinion-wanted/#findComment-99296
mugens another sticker... guaranteed to add a proven 193.5kw @ 6 wheels! (including steering wheel and spare)
i have a nismo sticker on my car about 7cm long on my windscreen... only makes 85kw though. a couple of professionals say that if i had gotten the full 30/45cm nismo sticker, i am proven to run 8's... :D
https://www.sau.com.au/forums/topic/6651-opinion-wanted/#findComment-99639
Just driving around today I noticed that chroming your petrol cover makes your car faster. This is because by chroming that part of the car, air will travel easier over that surface, thus improving aerodynamic efficency.
https://www.sau.com.au/forums/topic/6651-opinion-wanted/#findComment-99647
Man, when we all got our SDU stickers way-back-when, mine added about 35hp @ the front wheels to my trusty Corolla CSi Ltd. To this day it still amazes me, over a year later! Driving to and from work was never like this before!!!
Hopefully, when the Skylines Australia stickers come out, I'm gonna buy two of them. I'm gonna put the Corolla away and keep it for track outings only. Seeing as the SDU sticker is on the front windscreen of my 'Rolla, I'm gonna have to decide whether to put one of the SAU stickers at the bottom of the front screen for added traction off the line, or on the back windscreen for better aerodynamic stability at the top end. The phenomenal power that this sticker alone will bring should see me able to join the Highly Exclusive Corolla RH-6 club...
:lol:
God only knows what the spare SAU sticker will do when I get my R-32 GTS-t (four-door, of course) and attach it to that.
NASA or Fighter-Pilot training, anyone?
https://www.sau.com.au/forums/topic/6651-opinion-wanted/#findComment-100806
If you have to add stickers on your car when you don't have the actual part then you should be obliged to add a "RICE Boy" sticker on your front windscreen.
If you own a non-jap import and have Jap performance stickers on your car then you should be shot.
Just my opinion. (We've always been a little too fond of corporal punishment here in WA)
See'ya:burnout:
https://www.sau.com.au/forums/topic/6651-opinion-wanted/#findComment-100815
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
