My Rb20DET around locally used to pull a consistant 470km's per tank.
All were short trips hooning to Uni and back.
Check the O2 sensor, Ecu's coolant temp sensor, dirty injectors and apparently the AFM can also cause bad fuel consumption.
Dropping the RB30DET in dropped fuel consumption to 430km's per tank.
The base map of the PFC has now bumped fuel consumption to 520km's per tank.
Leech, I fill up around the same as you. 50-55litres depending how low I run it with the light on.
Generally 50litres is pretty spot on with when the fuel light comes on.
yea strange i might be mistaken but i though my late generally comes on at around 46 - 48L which seems very early but meh fuel level gauges are always so dodgy i just go off how many kms :D but my car is also fairly stock at the moment only thing is a full 3" turbo back exhaust when i put the panel filter, bleed valve and fmic on i can see it dropping a bit hopefully not alot though
better fuel economy in Rb30det because of lack of throttle usage...im quite happy most of the time putting around off boost....it has the same feel as the rb20 did on boost :D
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
