  • Replies 85
Just to try an inspire you all... i have added another video...
2004 Dutton Rally on Speed Week -SBS /FOX.
Fatz shows us how to get national airtime on the Speed Week Dutton Rally 2004 Review. There is one in every crowd... !!!
(Filmed - Goulbourne Police Academy Skid pan)
http://www.duttonrally.com/
http://kero.drifthost.com/videos/Dutton.Ra...ame.is.FATZ.wmv -15 Meg
Enjoy
they are 17 '9 but i would prefer to get some rims to borrow from sumwhere with shit tyres on them.. ill see what i can do tomorrow im tight with $$ atm i need new suspension.
so u really have spare rubbers u can sell for $20 do they happen to be on rims? :)
btw. how many spots are left, i have a friend who is interested as well.
also will there be lots of time where the pan is wet?
Fatz, I'll come grab those potenzas off u in the week! Wont have room on the day. Wish i knew a couple days ago, woulda had time to fit some to rip up tomorrow :P You dont have any shitters on rims i can fit to the 32 do ya?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
