Hey kids,
My bogan housemate is moving out due to financial problems so ive got a free spot in my 3 X 2 villa in Nollamara. Its got double lock up garage and is really secure in a really nice street.
Catch is that Vspec and I will be hopefully buying a house later this year so i really only need to continue my lease for 6 more months. After that you can continue the lease and find someone else (by then you'll probably be sick of me)
Rent is $100 a week .... plus bond and expenses (there really isnt a huge amount of expenses) and im only home half the time.
Its a really nice house and i need someone asap so if you know of anyone please let me know.
Cheers
Lauren
https://www.sau.com.au/forums/topic/66818-housemate-needed/
