Funky - thanks but I found one at work. Its a male DB25 -> female DB9 but I'll just have to figure out the pins and wire it stright in, otherwise I think I have a DB9-DB25 converter at home. Otherwise I'll get one off a mate who reckons he might have one laying around at home. I had some but threw them all out about 6 months ago, thought I'd never need a serial cable again! :P
Might build the IEBC tonight too.. :(
  • Replies 218
dont rely on this, as the kit probably (almost definitely) doesnt use just the 2 or 3 pins rs232 often uses, but all of them. if they only needed 9 pins or less theyd use the db9 in first place
cameron, should be in the mail now. Give it till monday depending on where you live?
Thanks for that NewKleer, I'd actually thought of that earlier today ;) It's logical! I found a DB25-DB9 at work today and a DB25 printer cable, and cut up that one. I cut off the printer plug end, then went through pin by pin working out what wire ran to what pin. So then I just soldered the wires onto the HC board where the respective pins would go (ie. pin 2 to pin 2, etc).
Then I applied some power, plugged it all in and it's all good! HC lit up in its green goodness and nothing appeared on the screen, so I just adjusted the contrast up a bit and text appeared :rofl:
Anyway cut a long story short, I've tested it fully and calibrated it so it's ready to go in my 180. I've also printed out the pinout for my ECU, so I might stick it in tomorrow night. But I cant wait! *thinks* 2 hours till bedtime, hrm I might go have a play :D
(BTW, funky if all my posts should be in SydneyKid's thread (rather than a group buy thread), move em over (you're a admin right?)) :)
Here's photos of the finish(ing)(ed) DFA/HC:
Hi Shan,
I'm registering interest for the group buy for the following items:
1x Independant Electronic Boost Controller
1x Hand Controller
1x Cable
Which should be $151.80 including GST if I'm remember correctly. If you want I'll just make it a square $155 for your help in organising the buy and helping us out. Unless I also need to take postage into account? If thats the does $160 for all those items posted sound good?
Anyways hit me up with a PM or call me on 0403578014 when you've got enough numbers for the group buy. I might have 1 or 2 friends interested in everything above except for the DFA.
Cheers and thanks,
Andy
Hi again Shan,
Just thought I'd let you know that I've confirmed that my friends are also interested. So thats now 1xDFA, 1xHC and 2xCable extra ontop of my oder. Can you tell me how close we are to the second group buy? Or maybe you could start a new thread and list all the interested people?
Would just like this soon thats all. :P
Cheers,
Andy
Well I got the DFA installed last night but my car was running like a POS, but that was because I took off my AFM the other day and I think (well, now know for sure) that the electrical connections were a bit crappy because of lots of steering fluid over the connector (I have a leak in the pwr steer pressure line). So tonight I cleaned it all up and reset the DFA (and my ECU) and went out driv.. err...tuning. :) After driving around for about an hour and a half, down to Clayton (uni) and back, it's noticeably different. I don't have an air/fuel ratio meter nor my multimeter hooked up to the O2 sensor, so I was just guessing and going by the 'feel' and sound of the car. It certainly feels more responsive and harder coming onto boost. And driving on the freeway, my (loud) exhaust is quieter because I don't seem to have my foot as far down on the accelerator. I know because if I turn on my air con, I have to accelerate more on the freeway and my exhaust becomes louder. This is the opposite.
I'm happy with it:) I just need to build some kind of air/fuel meter and Jaycar/SC have a few projects of the like. Or I could just jam my multimeter on the O2 signal to watch the voltage but with the update rate of it, it might not help much. But yeah, no more burbling when slowing down in gear with 2k-3k revs :) Andddd no more backfiring when totally booting it after changing gears; well sometimes it does but its not as bad I don't think :)
Next up I'll build the IEBC, but I'm not in a hurry because I'm awaiting a Greddy boost gauge from Nengun in the mail. :)
does any one know where i can get the r33 rb25 det ecu pins? I can't find it. I finished building the IEBC and handcontroller. I used the 12v that goes to the head unit to test. Was very happy when the screen lit up. I think i'll use that as the power as i don't want to chop the ecu wires too much.
edit: How much for the digital thermometer. I might be up for 2 or 3 of them oil and water temp and 1 for me bro :)
getrippedoff, I think you guys do have enough for a second buy... Just wait till Tuesday when the last orders have reached their owners and then I'll get started on group buy #2 on a new thread.
BTW I have tracking numbers for the packages I sent out in the office, I'll PM them to you guys when I get in tomorrow.
edit: How much for the digital thermometer. I might be up for 2 or 3 of them oil and water temp and 1 for me bro :rofl:
For those making these kits, the APEXi AVCR/SAFC2 wiring instructions might be very handy. I used the SAFC2 instructions to find the pins on my SR20DET ECU for the DFA because it uses the same ECU pins (AFM + power + GND). It looks like the AVCR instructions show the #1 injector input also so that might help with the IEBC. The instructions have ECU pinouts (well, only the pins you're concerned with when installing a AVCR/SAFC) for almost every Japanese car around.
They are on the APEXi website at:
AVCR: http://www.apexi-usa.com/productdocumentat..._savcr_wire.pdf
SAFC2: http://www.apexi-usa.com/productdocumentat.../AFC2Wiring.pdf
I'd also gotten some doccos from a quick Google search which included wire colours and stuff which was good for the verification that I was looking at the right wires. Try a Google/Yahoo/etc search for 'ecu pinout r33' or something. :cheers:
man ... i think my iebc doesnt work ..has power.. injector signal ..and a soliniod.. but nothing .....dunno what i did wrong putting them together.. but its pissing me off
Matt
yea she has power ..first pair of lights are working.. other than that ....nothing...getting my uncle to have a look at it today.. hopefully its nothing major
Matt
if u turn up the % on the hand controller the 3rd led will start to blink once you have reached 100% it will be on fully. U will see it getting brighter as you move up in the percentages.
rom.
Guest
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
