Hi all!
Can anyone recommend a good clutch for a r33 gtst that can handle approx 300rwkw? I've been looking around, but everything seems soo expensive!! The car is used for alot of traffic driving, and for drags and track work. So it has to be pretty resilient! The last clutch I had was an exedy twin plate and it only lasted me 1 year!!! Its not worth spending another 2.5k if thats all the wear i'm going to get from it :P
Also, can people PM me their experiences with Jim Berry in QLD? (good and bad) as i was also considering asking him to build me one...
Any help would be appreciated!!!
Mona
https://www.sau.com.au/forums/topic/66924-clutch-for-r33-gtst/
I havent used Jim yet, a lot of the guys I race with on weekends at Qld Raceway have had Jim build clutches for them, and they cannot speak highly enough of his service and expertise. I won't hesitate to send my 33 there when a new clutch is needed. Just my $0.02 worth.....
Go Jim Berry. Im getting a clutch built by him at the moment. Ive done my research and i havent heard anything bad about him. I spoke to him for an hour on the phone and he knows his shit! Why dont you ring him and ask if he can rebuild your clutch? 07 3847999.
Shaun.
go to any clutch shop and ask them, the clutch should not be expensive especially since its a push type... dont bother getting a button clutch or even twin plate its not necessary...
a good organic full face clutch would do the job and be easy to use (only bad thing is the pedal will be heavy!)
i had a pretty heavy duty clutch in my old r33, it was from racebrakes and it cost 250 for the clutch kit and 300 for fitting just as a guide.
OK, just got off the phone with race brakes in melbourne:
Entire kit for R33 GTS-t
Full faced organic with heavy duty pressure plate, + release bearing = $580
Then there was some other kit with a ceramic coating??? and sprung centre (it wasn't a button ceramic clutch, but I was told it has plenty of bite, and is much more streetable) = $650 (again, entire kit)
Ok guys... I ended up getting a 4puk, ceramic sports clutch! clutch plus fit was $1250. I went with Western Clutches at St Marys! Big thumbs up to those guys!!! They were very helpful and managed to fit me in on short notice! :D
I did want to go with jim berry, but it was going to take to long and i couldn't afford to have the car off the road :)
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
