Hi guys, I have had an ever increasing number of people ask me about tuning their car without going to a dyno. They may live too far away, not have the budget or they simply may want to do it themselves. I have accumulated a few A/F ratio meters over time. I thought to help guys out, I might rent a couple of them out. They are not too expensive to buy, but the maintenance can be relatively high, you have to clean the lambda sensor and perform calibration regularly.
So......
How many would be interested in renting one for a week for say $100? That would cover maintenance and repairs etc. What you would get is;
*a wide band lambda sensor
*long lead to reach to the tail pipe
*a clamp for holding the lambda sensor in the tail pipe
*a meter and controller with sensor preheating for accuracy
*a mount and vacuum cup for attaching the display to the windscreen
*a cigarette lighter power plug & supply
*a full set of intructions
*a laptop interface and logging software to load (not necessary for tuning)
*all mailed out to you in an aluminium case
What you don't get;
*you are doing the tuning, if you damage your engine it's your problem
*if you get busted breaking the road rules, it's your problem
*I don't have time for dial up support, maybe email would be OK though
*insurance, if you break it or loose it, you pay for it
*a lap top, you supply your own, if you want to do logging
*credit, you pay up front and there will be a deposit (not sure how much yet)
*freight, you have to pay both ways, it's light, so $10 should cover almost anywhere in Oz
*instant supply, I only have 2 suitable units and I don't want to buy more. So you may have to wait until one becomes available
*to use leaded fuel, it must be unleaded
* to send it back dirty and greasy, clean it please
*your deposit refunded until it is received in good condition
This is a survey for me to judge the response, so post away. If I get enough interest I will be ready to go in about 3 weeks, as I would have to clean, service and calibrate the 2 units.
Awsome Idea,
I was charged $50 for 15mins of driving up and down the road I was not impressed I didn't get to load it up in top gears only 2nd gear.
Have you got any Second Hand/New ForSale ?
:P
Nat
If its a brand name unit such as the Autronic model, they are expensive, i say make people leave a deposit of $500 bare minimum, just incase something happens.
Because you know what people are like, hopeless.....
If you have a quality unit for hire now, i will hire it immediately.
$100 is a fair price for a week, + return freight/post to you.
You can get some preety good wide band units off the net now for around $500-$600 with controller, which is a great price if you want to tune your own cars.
Let us know either way.
Cheers
sounds like a very good idea :cheers:
Yep, I know it's a good idea, but how many people would actually rent one for a week for $100? That's the question, if I get enough I will do it. We can then start a thread on people's experiences with tuning on road and the results they get. Should make a good reference for others.
I need a few more to make it worthwhile, so let me know:cheers:
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
