  • Replies 128
oh shit, he got a honda vtec!
correct and just got finance approval so hopefully wednesday or thursday can pick it up.
insurance is a bugger though its about the same as the skyline
*shakes head*
yes the plan the now is to save the house deposit as fast as possible. get a house and then buy a 33 or 34 gtr after a year of having the house.
what the litre and power of a Mitsu Galant GSR??? i'm happy that its got AWD, full electrics.
i'm going to be looking for one of these come th end of the year when i sell my line and get my tickets for Germany world cup next year.
Was tempted to save up for 2006, but am going to wait for Euro2008 in Switzerland/Austria, 2 places I want to go anyway, but because they are the joint hosts am going to that.
2008 will be a better option because I will have finished my apprenticeship & been working full time for a couple of years woohoo :Bang: .
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
