  • Replies 141
finally broke the 8mins and got 7'59:900 in the lotus challenge...LOL  could probably shave another sec or 2 off but i cant be stuffed.  learnt some new tricks in the process though.
el capitan is a great track!!
Damn you got quick,
Second attempt got a 7'57.284
I like Citta di aria for next track.
Just ran this track last night as part of the BMW M Cup. This track is awesome! First time around the track ever got a 7:53 in a BMW CSL modded.
Just noticed the 7.03 you got there Angry, looks like ive got a lot of improving to do! I'll have to race the R34 Nur VSpecII around there tonight.
did a 8 min 50 on first go in a Ford Mustang,
415 hp and lightened the full 10%, with sports - soft tyres on the front and sports - medium on the rear. Has nice cornering manners, brake into the corner and it really hugs the corner unlike some others I tried which just seem to throw you off the track.
did this in the arcade mode as I only hired it for a day.
check out the GTR story (english) vid on the net, has a german racer take an R34 round the track, he was the nissan gtr test driver and has done something like 10 thousand laps in his driving career on the nurg, he is pulling 170 mph in some areas passing traffic like a rocket!
There is a Tribute to the Nissan head test driver on the track a corner before the long straight.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
