I dont disagree on anything for a change ;) maybe soimethings wrong with me hehe
Dr D. The Top secret rom has to go....
When i ran 20 degrees i got 30hp more midrange wow! @12psi
Back to 15deg and i can run more boost but only 8hp more top end but lose driveability mid range!
Adam My turbo specs do match my graph thats ok im happy with that...im not particularly interested in a vertical dyno chart like um.. :) ps 4500rpm
Rob i guess u have to like a dyno and stick with it so u can monitor inprovements..It is all in all only a tool for development :) But however what im saying is that i got a minimal increase by doing certain things and went back to the same dyno!
Thanks steve i didnt think so either but wanted some feedback just incase i thought i was greedy..
cheers
mac
  • Replies 104
Maybe sell it for cash+swap for standard ecu? The top secret rom would be a good upgrade for someone who couldn't afford a s-afc but wanted to get rid of the standard ecu timing problems.
BTW, you're not greedy for wanting more power. It happens, even to the best of us :)
awesome.. my mates R33 has one also.. never seen another around like it, diff cooler, the lot. :-)
apparently another mate read somewhere that they only made 100 or so of these from the factory.. nice little score! :(
Shaun
Originally posted by GTS-t VSPEC
I guess I should expect this, I've already answered others on the forum. Probably should change my user name.
My R33 GTS-t has a VSPEC diff, yes it does have the fins on the diff like the VSPEC's. That means that I have the benefit of both traction control and Active LSD. It came from the factory with this so I presume there aren't too many of them around.
The Active LSD is really cool for high speed cornering, causing the back-end to quickly turn in so you can keep the power down.
See'ya
:burnout:
BTW, you're not greedy for wanting more power. It happens, even to the best of us :(
Your right the Rom is a good upgrade for some people as i did lose power installing the standard one back in for a check, its just a matter of getting another standard unit now...
Macka are you running the stock turbo? If so I would have thought the thing woulda run outta puff at higher boost levels.
What does the dyno map do above 3500 RPM? Does it skyrocket or mystriously level off at some rev point?
What are the injectors doing (i.e duty cycle?) Fuel pressure? Is the pump suppling enough fuel? Fuel air mixtures may be deceiving. If for example the engine isn't keeping enough fuel in the combustion chamber the exhaust output appears rich.
Just some thoughts ......
Thanks for your interest Puckish
Look to the left at my avatar , that snail lives in my car!!
I have a large front mount and 550hp fuel pump
Injectors have a bit of headroom but i havent checked airflow % yet as i forgot...duh!
Gonna try at the drags tonight i have a special pair of slicks now curtesy of GTS-t VSPEC :lol:
It was an impressive run Macka, well done. I'm glad those racing slicks I gave you did the job, maybe I can line something better up for you next time. 12.98 will take some catching by the rest of us, but I'm prepared to bide my time until the bigger turbo is on.
Well done again, and nice to actually meet you.
See'ya:burnout:
PS: I'm not too impressd witht the 265's I put on, I still get shitloads of wheel-spin, maybe able to get some Potenza's for the drags, that should provide more grip.
Thanks...
how bout them bald Tyres. ey..
That was a freaky time ey...shocked me but she ran beautiful on 1Bar
Maybe the track was prepped better i managed a 2.254 60ft this time..
I thought id teach a V8 torry a lesson but he creamed me with a 12.5 hehe oh well
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
