No worries RedDrifter, I misinterpret too.
pplo, looks like your diagram is correct. Thats how I would have it set up. Block the PCV & inlet to turbo. If your catchcan has 2 inlets, I'd run 2 hoses from either side of the cam cover instead of just 1 side in your diagram.
Cheers!
  • Replies 160
I want a catch can....where can u get a decent one for a decent price??
I saw a link to this somewhere on the forums before, and though 'hey - I can do that'.
Of course, I havn't yet... but I still want to.
Has anyone used something like described here? (air compressor filter)
http://tsx.acurazine.com/forums/showthread.php?t=9571
I guess you'd want it bigger, but atleast you can see how much oil is in it, and it looks tidier and not as obvious (in my opinion) to a big stainless canistor.
I have also read (I think in that thread...been reading a lot) that you can/should run 2 catch cans? Is that right?
Cheers
Chris
Cheers pplo. Glad to be of some help.
eXc, thats a 'catch' that goes in line between your PCV on your cam cover and inlet manifold. It collects the oil that would otherwise end up in your intake manifold. You can also use it between the cam cover and turbo intake if the barbs are of the correct size.
Basically an 'inline catch can' like GReddy's design but smaller. You can't have these venting atmo.
I've got a Cusco catch can with a total of two inlet/outlets only. I guess that make it inline?? Can it be vented atmo?
If I vent it atmo will I need to place a filter on the remaining fitting?
Anyone with pics/diagrams showing a fitted catch can with only two fittings?
Cheers
Cheers
U can have it either way.I had mine inline until I upgraded the turbo and intake.
its vented to atmo atm. I would use a filter as if the police see it not filtered u most likely will get defected.
As this is very illegal.
  • 1 month later...
  • 4 weeks later...
ok guys
just looking at installing my catch can.
for those who have done this, I wanted to know how u blocked off the PCV and turbo lines? just some screws? how about where the PCV line goes into the rocker cover...just some kind of plug??
I will need to go them anyway just wondeirng what every1 else has done.
