TTT Posted March 24, 2005 Share Posted March 24, 2005 I'm not sure if I'm right here, but hear me out.. r33 gearboxes are tough as nails.. R32 GTR gearboxes are tough as nails. R32 GTR gearboxes are INTERNALLY the same as an R33 GTST gearbox (except for the front shafts thing..) SK has said this many times. all the GTR boxes and R33 gtst gearboxes he has opened up have been the same internally. so with the front drive shafts taken out of a gtr gearbox and the sump welded up, it is basically a R33 gtst gearbox. I have also heard many times that the R32 GTS4 (4wd) gearbox is IDENTICAL to the gtr item. it is the same box. and therefore, the drive shafts can be taken out, welded up and used for rear wheel drive, which is the same as a gtr box, which is the same as a R33 gtst box. hmmm.. r33 gtst box = $2K+ if you can find one. r32 gtr box = $1K+ R32 gts4 box = $500+ surely someone has stumbled across this already or at least thought about it. or maybe I am wrong about the whole comparison... Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/ Share on other sites More sharing options...
JH32 Posted March 24, 2005 Share Posted March 24, 2005 I don't think the R32 GTS4 box is as strong as a GTR box I have heard something in the GTR box is thicker than in the GTS4 item, but dont know what Sorry that doesn't help alot Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-1265843 Share on other sites More sharing options...
Sarumatix Posted March 24, 2005 Share Posted March 24, 2005 On the same topic, what options for gearboxes do you have with an R32 GTS-T gearbox? Will an R33 gts-t gearbox drop in? need some fitting? or not an option? Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-1265885 Share on other sites More sharing options...
GTRgeoff Posted March 24, 2005 Share Posted March 24, 2005 The casings are clearly different, and while the internals may be as strong, or even an identical item, the housing is what allows the box to remain optimal regarding location and running surfaces. So the answer is that it's a matter of conjecture whether one is as strong as the other. The GTR32 box could be put in without attaching the front prop shaft. Since the GTR feeds power to the front, and is nominally RWD it should be fine with little power loss due to the clutch unit hanging off the side. That said i don't know anyone who has done it. Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-1265955 Share on other sites More sharing options...
TTT Posted March 24, 2005 Author Share Posted March 24, 2005 I think someone in the R33/RB30 thread was going to/did do this.. Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-1266138 Share on other sites More sharing options...
CeJay Posted April 1, 2008 Share Posted April 1, 2008 Sorry for dragging up an old thread, but I did use the search function . Anyway I have a 32 gts4, running an rb25det. Now a few questions the general consensus is that gts4 boxes are almost the same as gtr boxes. Except gts4 boxes block is a bit different and a bit weaker? and the gearing is slightly different? Now would there be an issue to worry about replacing the box with a gtr item? due to my running an rb25det? I assume I'm running a modded tailshaft due to this? ( pretty much a noob in that respect) but read that you need to do that when running a 25 in a 32. Would I need to get another customer tailshaft made up for a gtr box replacement? Also is there anyway to tell if I actually have a gtr box or gts4 box under there. Ie something like a casting mark? Don't know too much about whats been done to it driveline wise, as I bought it with the 25det in it already, Just know that the gbox is getting noisy and vibrating, and it maybe on its way out. Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3761465 Share on other sites More sharing options...
trism Posted April 1, 2008 Share Posted April 1, 2008 im keen to know this as well. can i get a definate answer whether the gts4 box is weaker than the gtr box. also, the rest of the running gear, ie dif, driveshafts etc Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3762964 Share on other sites More sharing options...
Bumblebee Posted April 1, 2008 Share Posted April 1, 2008 theyre different. r33 gtst is the same minus the transfer case. gts4 is weaker Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3763282 Share on other sites More sharing options...
vinnie32GTS4 Posted April 2, 2008 Share Posted April 2, 2008 The GTS4 Gear box has a higher gear ratio i think giving it more acceleration..and yes it is not as strong as a gtr Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3763892 Share on other sites More sharing options...
trism Posted April 2, 2008 Share Posted April 2, 2008 so, how much power can you reliably put through a gts4 box until you should start thinking about finding a gtr item? Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3763986 Share on other sites More sharing options...
CeJay Posted April 2, 2008 Share Posted April 2, 2008 Yes thanks for that I still want to know though 1. will a tailshaft that fits in a gts4 box fit up to a gtr box with no issues? and 2. Will a r32 gtr box bolt up to a rb25det engine fine? since ive got a gts4 box mated to a rb25 atm. Since im not running an rb20det in my 32 gts4. Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3764461 Share on other sites More sharing options...
Bumblebee Posted April 2, 2008 Share Posted April 2, 2008 gtr box should bolt up. should... hahah Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3764521 Share on other sites More sharing options...
CeJay Posted April 2, 2008 Share Posted April 2, 2008 pfft should lol, anyway anyone else know? Also how do you tell the two boxes apart when they are on the car? Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3764535 Share on other sites More sharing options...
Luke_ENR34 Posted April 3, 2008 Share Posted April 3, 2008 so what gearbox would i have in my R34 GT-four. Its 5-speed manual using the attessa system. Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3768490 Share on other sites More sharing options...
CeJay Posted April 8, 2008 Share Posted April 8, 2008 anyone have any more info? Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3779294 Share on other sites More sharing options...
dwest Posted April 10, 2008 Share Posted April 10, 2008 My GTS4 tranny took a crap on me at 480whp last week. I am swapping in a GTR tranny from what I heard its a direct swap. I will fill you in after the 19th. Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3785568 Share on other sites More sharing options...
GTS4WD Posted April 11, 2008 Share Posted April 11, 2008 The GTS4 Gear box has a higher gear ratio i think giving it more acceleration..and yes it is not as strong as a gtr According to the workshop manual. GTS4 have a shorter 1-3 (and maby 4th but dont remeber 100%). Because the gearing is shorter, it offers better acceleration.. Or do I have my bigs and smalls mixed up? Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3787940 Share on other sites More sharing options...
vinnie32GTS4 Posted April 11, 2008 Share Posted April 11, 2008 According to the workshop manual. GTS4 have a shorter 1-3 (and maby 4th but dont remeber 100%). Because the gearing is shorter, it offers better acceleration..Or do I have my bigs and smalls mixed up? nope u is right Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3789239 Share on other sites More sharing options...
sivart Posted June 6, 2008 Share Posted June 6, 2008 ya cant really tell the gearboxes apart on the outside only the way is to crack it open and check the internails of it. cause i have 2 gtr boxes and a gts4 boix and i cant tell the difference Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3924281 Share on other sites More sharing options...
Kranker Posted June 7, 2008 Share Posted June 7, 2008 This is to Luke_ENR34: you've got the same as an R32/R33 GTR, internally same as R33 GTST, so plenty strong. Link to comment https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/#findComment-3925741 Share on other sites More sharing options...
