Guys, I recently had my R33 broken into at a shopping centre carpark and almost had it stolen, they got as far as the key barrel so another 2 minutes and I swear it would've been gone! ....Just to let you guys know how they got in.
They struck the anti-carjack button (located on the drivers door) for the passenger door with a long object which they managed to wedge through the top of the drivers door/glass. It's obvious that they've done this before 'cause there was minimal damage to the car.
Either way. I think disabling this switch is a good idea.
https://www.sau.com.au/forums/topic/68338-dont-wanna-get-ya-line-stolen/
  • Replies 41
hat the hell is an anti car jack button
its so easy to break into a skyline hehe, i locked my keys in mine in a shopping centre i was there for about 3-4 mins breaking in lol first time id done it.. and several people walked past and joined in, i even got some young asian guys to help me and my friends!! no cops showed up or nothing drove off in my car no one said a thing!!
are we saying something about asians?? Cough cough lol just playing..
yeah i did the same thing WITH MY ENGINE RUNNING!!!
being asian and wif a few of my mates there tryin to get into it no one even sussed us out..
took about 5 mins, there more ppl willing to help than stopping to question us if it was our car or not..
if i saw a few guys covered wif tattoos tryin to get into a car it's 000 straight away.. my 2 cents :thumbsup:
Yes for sure. This was one of the first things i looked out for. But rather than disable it(cause i find it useful), i've put like a missile switch cover on it. Also disable the remote boot by pushing the latch down in the boot. Makes it harder for your amps to get flogged. And always always use the clublock. I know sometimes you think its pointless cause everyone says that they can be gotten around and sometimes we just can't be arsed, but when you see your car gone, u will definitely kick yourself.
Oh yeah, and don't EVER fool yourself to think your immobiliser is going to be enough. This is not piece of mind. Even if it was the ultimate unstartable, they will still try, and u will be left with a 1-300 dollars job to fix the damage. Visual deterrents go a long way.
a) I think there are good ones and bad ones.. the good ones work alot better
B) (If you have a good immobiliser/alarm) If you get your regular idiot who thinks they can break a window and force the ignition barrel to start your car a club lock might save you alot of damage.
c) (if you have no alarm) It will slow them down and cause more noise.
(and the down point)
d) (If you have a good immobiliser/alarm) It gives the impression that you are putting trust in the club lock to secure your car... so people might think all they need to do is bust a window, break your lock, and force the ignition when infact its the immobiliser which is secureing your car... so you end up with more damage but your car is still there.
I remember i borrowed my mums car years ago when i was having a clutch redone in my old pulsar. put a club lock on and went into work. came back and relised the key for the club lock was on the key ring with my car... and the spare was in the ash tray of my car.... :Oops: but with a twist and a pull i could lower the clucb lock 1 notch. a few attempts and she was off. 2 minutes work :uhh:
A better way is to put it on backwards, i.e behind the steering wheel, rather than infront, the guts of the clublock should be up against the steering wheel hub, so much tighter fit. If you can force the notches then get rid of it, it is broken. Get one with lock pins(like the ones in gym equipment seats).
I Disabled this switch after some helpful advice from my engine tuner Matt "hitman", apparently this switch is how his skyline was broken into.....
If you cut the brown wire under the door control pannel leading to the switch, you will still have the functionality to lock the passengers door, but not unlock it.
Cheers
Yeah, i always turn the club lock back the front so the barrel faces the dash. The Bast#$ds hit the barrel with a slide hammer, makes it pretty awkward if between wheel and dash.
Also bought a good quality wheel clamp (if Going away or something) "keep-it-clamp -it" are the best, looks pretty bad but the car is still were you left it. Can never be too careful these days!!!!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
