can I suggest that if this 'hiccup' is only happening on cruise (ie. part throttle/light load) then you should look at your O2 sensor. as when running in closed loop your ecu is trying to target a stoich AFR for economy. It does this by reading the value from the 02 sensor, if this sensor is stuffed it won't run right on cruise, but will run fine under full throttle conditions.
Also, as Abo said you cannot use a Z32 with an unmodified ecu. the car may run, but it will run like sh1t.
I never though about the O2, will definately try that. What are they worth do you know??? Also heard a rumour that you can use the falcon ef/ el sensors.... How true is this theory???
Maybe drive to melbourne when the vic guys are having ameet of some sort. It only takes a few minutes to swap over a stock ECU or AFM. I'd hate to see spend money on something that doesn't fix your problem.
Also thanks Abo bob Its a good idea to swap and try before buying, just gota find the time to make a trip down.
I think that is true about the falcon ones.  The information is definitely available somewhere on this forum.  There is a very long thread about o2 sensors so look in there.
Do you know where I can find it here. There is so much info on this site, I wouldn't know where to start???
Anyone confirm the falcon O2 sensor theory???
the o2 sensor wont affect your cars running smoothness or hiccuping
the 02 sensor is used by the ecu to save fuel when the throttle isnt at WOT
so its only used when you dont floor it, the ecu checks this value to lean out the fuel mixture to save fuel. it shouldnt make the car "hiccup". the o2 sensor from the ford falcon works and i have one in my r33, worked with stock ecu and powerfc
the falcon o2 sensor is a generic sensor and its used on a few cars actually.
its just easier to ask your local parts place for a ford au falcon o2 sensor
rather than a skyline one cos then they go what model and what year and they wont have it on your system or give you a o2 sensor that is for the r31 skyline as their computers/database usually only have the r31 as it was aussie delivered
that being said i dont think the o2 sensor is causing your problem. you can unplug it to test that theory if you like, it will just run mega rich and waste fuel. the plug is on the dump pipe just after the turbo heat shield. its a little prong thing that goes into the exhaust pipe. the plug with have 3 wires, just disconnect it
So you don't think its the O2 sensor then???
The car only hiccups on cruise (ie; hardly pushing down on the accelerator or when you start to back off) sometimes it may do it when you slow down to a stop without braking...
The mixtures on the dyno appeared fine (4 runs). Could that just be luck, afm, o2 sensor, ecu or what???
When i drive my car in the morning, it plays up (like the AFM is unplugged), but when i drive it home 6 hours later it's fine. My auto electrision told me my ecu isn't in the best health (it wouldn't let my AC turn on), so would the morning driving be my ECU or AFM? Are R33 and R32 AFM swapible?
hi marcus,
did you sort anything out after our phone convo? let us know how you go
Hey Paul,
Cheers for all your help. I am waiting on a stock BOV to try (in terms of the bov noise) and am waiting on the O2 sensor also to come in.
Will keep you posted on how it goes...
Marcus
no probs, i noticed (when i was looking for stock afms) you were inquiring about a z32 afm, the z32 wont work with the stock ecu unless its been remapped or you have an safc (not sure if you knew or not)
Cheers, but yea the boys told me the same thing earlier. However after our discussion I don't think its afm... Will find out when I try the o2 i guess...
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
