I have used the search function, but it didn't really answer what I need to know, so I am hoping someone could help me out.
Right, I am importing a 33 gts-t with some mods, and I want to get permits to keep any hassle to a minimum. What I need to know is does an engineer need to inspect these mods, or can I get them in advance???? I have had a look on the DPI site & it says something about requesting approval to modify, but it dosen't really make sense to me.
If they need to inspected, can they be done at any pits??? I think there is one at Warwick, which is the closest to where I live. Otherwise I can get it straight away at Welshpool when I collect my car.
Hopefully someone can help me out, these are all the mods the car has at current, and I won't have the standards :
Adjustable suspension
Airpod
Rims
Exhaust (cat-back, pretty quiet anyway)
Muffler (why it's quiet)
Steering Wheel
Leather gearshift (only included this because it seems some cops will look for eeevvveerryyyttthiiinnngg)
Of these, what can/can't be permitted (exhausts seem to be VERY inconsistent)???
Hope someone can help me out!!!
https://www.sau.com.au/forums/topic/68443-getting-permits/
If you are importing it, it must be stock when complied. After that you can mod it. Permits are issued by the pits, whether or not you will get a permit depends on what exactly you do. For example, wheels can be changed, but the track must not be exteneded by more than 25mm.
For best results, I would suggest you call dpi and get it straight from the horses mouth. G/L
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1269232
The pits now do not need to give permits for Airpods, Intercoolers, Strut Brace's and the like. Also you can not be yellow stickered for them.
Blow off valves you can get permits for but "must remain quiet in operation" ie, impossible show the copper your permit and get done for "Excessive Noise"
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1269405
Anything that is different from standard they can and will sticker you for, right or not (or the cop that stickered me wasnt wanting to play).
Either way get permits just to be safe so u can stick it to the cops like i do now, they tend to not bother checking my car when they see the permits (so far anyway, touch wood)
I passed my bov by running the standard valve with the hks blocked off so it sounds quiet and permitted it:D
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1269415
r u sure abt the pod filters? ive never heard about this? would be very interested to kno if its true becuase thats the onli modification i have :)
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1269875
i thought anything that result the car for excessive nosie ie POD filter are illegal.
whats the dpi number and what mods are legal and what are illegal, does any1 have a list? cuz im importing a skyline too, and i would hate to be "p" target too ive got 4 months left til i get off my p's and i know for sure when i get the car, the cops will give me sh#t.
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1269907
hey if you buy a car of someone and they have all the permits for the stuff they installed, then you change it so its registered under your name and not theres will you have to run the car over the pits again and get all the permits again ? or can you just take the previous owners ones?
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1274723
r u sure abt the pod filters? ive never heard about this? would be very interested to kno if its true becuase thats the onli modification i have :D
as far as i have been told, as long as your pod filter is bolted to the chassis (via a bracket like the Apexi one) it can't be defected. the reason they can be defected is due to them coming loose.
but it usually depends on the cops attitude, i have been pulled over a few times and i have an APexi pod and a loud exhaust and they didn't say a thing.
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1274762
ive got a permit for my FMIC and induction system (i assume this is just my pod) previous owner of the car had it.. it has gotten me off almost getting a yellows for my *exhaust* lol!
copper told me he was going to give me a yellow, so i whipped out the permit, and just said 'yeah the air comes in thru the pod, runs thru the FMIC, then passes out the exhaust, so it needs to be large and hiflowing due to the air coming in' cop: '.......oh... well.... its good you have a permit there! *grumpy whinge*'
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1274999
It's wierd all the different responses, I my self am not totally sure, but was under the impression you needed permits for Pods, FMICs and certain sized rims. The Pods still have to be fastened regardless. I think you gotta be lucky not to get a cop in a bad mood by the sounds of it!
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1275355
i just got my 32gtr licenced and i HAD to get a permit for my apexi pods and fmic (even tho it was stock?).
It does save my ass later i guess and a permit is only 30 bucks and can put as much as you want on there (as long as they pass it)
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1275565
also, with the turbo timer, you are allowed to have them, but it is illegal to leave you car running while it is unattended. its kinda like the shops that sell bongs, but you arnt allowed to use them!
that said, it is a good idea to unplug or disable/hide your TT when you take it over the pits.
steve
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1276534
Morlock, Roy from C-red has a permit for his CF bonnet, has something to do with the date the vehicle was manufacutred and whether or not it predates the applicable ADRs.
Kinda weird, the older a car is the more you can modify it. Defys logic IMHO, you can build a twin turbo V8 as long as its old enough its legal, but you cant do it to a modern car with better suspensions,brakes etc. ADRs certainly dont help make the streets safer in regards to vehicle modification, just encourages the modification of older cars. Sorry, starting to rant :rofl:
https://www.sau.com.au/forums/topic/68443-getting-permits/#findComment-1279793
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
