I have converted my automatic R33 GTS-t to manual transmission. I am about to fit a modded R33GTS-t manual engine from another R33 shell I used to own (a manual car) into the auto shell, along with an Apexi Power FC,on which this engine used to run. What ecu and engine bay loom issues can I expect? Can I totally remove the auto box ecu from the loom? The gearbox loom extensions and plugs differ, I have a manual box loom, can it be adapted to mate up with the rest of the auto shell loom? I have found the clutch switch connector taped into the auto cars loom and have attached that to the clutch switch, any other issues in the pedal box region? Should I try and get hold of a full manual car engine bay loom and swap that over? The throttle body potentiometer also differe, from auto to manaual. if I swap loom connectors will the auto pot work with the Power FC, or do I need to find a manual throttlebody asembly complete with throtlle pot?
All and any info welcome, elecronics are NOT my strong point :)
Thanks!
