Guys, sometimes it might seem like you're not having the greatest day, but check out how quickly luck can turn around.
Woke up this morning (my birthday) still kinda hung over from a massive Easter weekend.
As i'm getting ready to go to work, I get a phone call from the real estate agent telling me that I had been outbid on a house i had pretty much thought was mine :kick:
So I've been sittin at work all day feelin sorry for myself, wishing i was elsewhere.
Until about 4pm.
There was a massive noise outside the office, sounded like someone had crashed into my car. Here are some photo's of the scene that confronted me when i got outside -
https://www.sau.com.au/forums/topic/68687-im-a-lucky-bstard/
Apparently the slasher blade on the boss's tractor hadn't been done up correctly, and as soon as the tractor was started part of the blade (about 10cm wide by 20cm long) broke off and was spat out the back.
As you can see from the photo's, the blade must have only missed my car by about 10cm.
The boss's patrol never had a chance to move...
The boss is still pretty cut up about it, going nuts at the moment on the phone to insurance companies.
It wasn't so much the actual house I was interested in, it was a bit of a hole. Was a pretty decent development opportunity though, as well as the fact it had a massive 12m x 8m garage...
But as you say, another one will come up.
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
