Anyone actually running the clutch in question? Input from someone who actually has it would be helpful, as this is my preferred option and it'll be done very soon.
I have a 9-puck Brass button Xtreme clutch, with 2500lbs pressure plate :) Best $1k I ever spent on the car.
Yeah, it's a pain sometimes in traffic, used to do the peak hour thing every day a while ago - pain.
These days in the wet its more painful than ever, i take off in second with a slippery road or its well too easy to spin. But a little bit of skill and you'll be fine.
just went and had a look at the clutch, mmm purple :rofl:
Strich9 - im used to a quite stiff twin plate, and then a pretty much on/off single plate in my mates wrx, so getting used to this new one shouldnt cause too much of an issue...hopefully.
Haha @ stall it!
Thats exactly what i did when i had mine installed after a standard one....
I have the same clutch too and love it, have been quite brutal to it with NO slip or probs at all for the last 6 mths. You still have a heavy pedal that only really shows itself when in traffic like Strich9 said and i found it can shudder a bit when it warms up in the same situation....but other than that its all good!!! :D
i didn't stall it!!!! :)
god damn this clutch is nice... nice and smooth when you want it to be, or let it out a bit quicker (i accidently did after driving home from hyperdrive) and it grabs... oh it grabs.
im with you strich9, best $1000 ive spent on the car.
Glad you like it Mitchell.
Told you they were good and for the rest of the peoples, the only reason it was $1K is that a s/hand flywheel and bolts were needed as his original one was designed for a single OS Giken.
Cheers
Ken
i think i need to get myself a new clutch.. it seems to be getting worse too. If i put my foot down in 3rd, 4th or 5th it starts to slip... but doesnt in 1st and 2nd. Im guessing its putting more pressure/torque on the clutch in the higher gears.. but dunno
can't understand why some people were saying the xtreme clutch would be hard to drive with........
since having manual conversion thats the first clutch i've had and it has been a beauty since day 1 and still is today......
adrian :D
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
