Sorry Man I'd lend you the stuff, If i had it on mine.
I just imported a Cefiro and I pretty much need to find all that stuff myself, so let me know if you find it and maybe we can halve the costs or something.
I have got 16' rims but they hand to far out the side's of the wheel arch, but I am possibly getting some rims off a s13 which should fit(hopefully)
https://www.sau.com.au/forums/topic/68818-need-help/#findComment-1283679
Can someone please help!!!!!!!!!!!!
I've just got my hands on a r32 4door problem is
after only having on the road a week a problem
has show it's head. :P
loses power and either stalls or idles between 1-2k
bouncing betwwen the 2. This problem only happens
after i've been driving for about 15 mins.
Does anyone have any insite. :P
https://www.sau.com.au/forums/topic/68818-need-help/#findComment-1292104
 has show it's head.   :rofl:
Does anyone have any insite.   ;)
Not sure about skylines, but It could be the cold start valve, had same problem on my old 280zx, and I replaced it. Problem fixed
https://www.sau.com.au/forums/topic/68818-need-help/#findComment-1292621
Hey Jaik, were about do you live man i just moved into queens park.
Down the road from you practically if you are still in vic park
Any chance you have a standard drivers sear lying around. I dont think the coppa's like recaro's over here.
can you email me
[email protected]
I would be interested in buying and borrowing those parts you have.
https://www.sau.com.au/forums/topic/68818-need-help/#findComment-1294056
wicked, that is one less thing i have to worry about on my car.
YAY!!!!
my budget for my cefiro has been blown way out thanks to shipping/drift damage
im guessing the previous owner took it for one last thrash before they dropped it off at the docks.
At least there is some rubber left on the tyres for me to rip it up
looking forward to getting sideways around welshpool in the coming weeks
https://www.sau.com.au/forums/topic/68818-need-help/#findComment-1296313
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
