Most workshops I went to will only machine it to make the top flat again. They won't "deliberately lighten" the stock flywheel. The reason I was given was that if you lighten it, you weaken it. If it's too weak it can shatter, and if it shatters while you're driving the fragments are likely to break through into the cabin and cut your feet off.
If you want a lightweight flywheel, I'd recommend getting something like this:
from Unique Autosports www.nismo.com.au
I bought one and had it installed when the new clutch went in. I noticed the difference instantly.
  • 5 years later...
Yeah it's not terribly bright. Up there with welding a diff in a daily driver (and I know your sentiments on that Hamish :(). Always buy a lightened flywheel. Meh @ weakening the structural integrity of 15-20 year old metal.
Thread dig to the maxxxxxxxxxxxxxx
