So guys what did you think?
I didn't watch the whole race as I had an early board meeting today, but I switched off just after webber threw his podium away.
Anyone know what happend to him? It seems he just lost the back end in a big way coming into turn 10(?).
It was good to see webber get a good start for once and get past Heidfeld and good to see him able to hold off Rowf. I sooo thought this would be his podium chance, but not today.
I heard on the radio this morning he finished 6th. that's not to bad.
https://www.sau.com.au/forums/topic/69237-bahrain-gp/
Good race overall, although Webber through away a good chance at a podium. From the replay, it just looked like he lost the back end of the car which isn't surprising given that Williams have been struggling with rear end grip all weekend.
Webber also had an exciting battle with De La Rosa towards the end of the race, although I thought it was going to end in tears with the way Webber was swerving all over the track to block him whenever he made a move to pass. Thought Webber's defensive driving was perhaps a little over the top to be honest as he was really struggling and De La Rosa had good pace (over 1.5 secs a lap quicker), but all ended well (although Webber unfortunately lost that battle).
https://www.sau.com.au/forums/topic/69237-bahrain-gp/#findComment-1282395
Yeh, there have been a few instances now where Weber has been tuff the get by, and in the back of my mind perhaps a bit unsporting. Give him a few more races to settle into the team, he is doing a great job...but i fear he may just be a little too hungry for a result, and that could ultimately be hurting him????
Anyway, good to see he is making others work for it, just hope he doesnt think Schumacher banging wheels is ok...but i suspect once he gets a result he will settle down.
It was another good race...lol and Coutlahrd was again in the points, and is 5th in the championship:)
https://www.sau.com.au/forums/topic/69237-bahrain-gp/#findComment-1282646
He just made a mistake and paid for it. de la rosa set fastest lap of the race catching him so it was inevitable that he woudl get past but webber certainly made him work for it, great to watch! given that the williams is a bit draggy and not able to generate sufficient rear downforce on the faster circuits i predict that webbers day will come at monaco! If he qualifies well which is likely he could be hard to beat.
https://www.sau.com.au/forums/topic/69237-bahrain-gp/#findComment-1282711
:(...de la rosa is probably sniffing around looking for Saubers second seat.:(
I wonder how much patience Sauber will have with JV, Massa is running circles around him:(
With Sauber goign to use BMW engines nect year, what are the chances of pizza boy jumping from a testing role at Williams to Sauber for a race seat, hell he was thinking about a seat in Indycar:(
https://www.sau.com.au/forums/topic/69237-bahrain-gp/#findComment-1282866
yes, webber certainly doesn't give up spots easily. that's not really a bad thing providing he doesn't take it any further. I think he is now right on the limit of what is good/fair race driving. I wouldn't call him unsporting just yet, he is racing afterall, and needs points just as much as the next guy. He just needs to be aware not to push it any more and end up getting a bad rep amongst the other drivers.
I think you are right too, once he has a result he will settle down. I think losing that first BMW podium of the year to heidfled will be putting himself under a lot of pressure now to get ahead of Nick. I think that loss was no fault of his own, fisi ruined both their races that day. Bahrain, I guess he was just pushing to hard. He will get a result though, and he will be better off once he has that monkey off his back.
https://www.sau.com.au/forums/topic/69237-bahrain-gp/#findComment-1283408
meh, I'm fine with how Webber held him out, with the exception of the first 2 feints he made when de larosa was beside him....the rest was fine, he was just loosing outright pace in return for holding the position. A less rusty driver would have been past him within 2 laps, I can;'t beleive he held out for 6 laps
I've raced against a driver with a really wide car before....and it is *soooooooooooo* frustrating. But hey, as long as they follow the rules it is just a part of racing.
https://www.sau.com.au/forums/topic/69237-bahrain-gp/#findComment-1284216
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
