Duncan it appears I'll have a need of this product soon, so I'll let you know when I'm ready to go.
I recall that JE thought this couldn't be done at a value for money price as each GTR would require calibration etc etc. How did you clever buggers overcome that?
  • Replies 317
Posted Images
Thats because JE is a prize goose :) Basically these adjust the output sooo much within the range available that every car (and driving style) we have fit it on has had no trouble finding a good setting to work with
And I'm intrigued by why would would need a 4wd controller if you have a and rb26 gtst :cheers: Got plans?
ok duncan the tuners have the car finally.... and should have it ready for you to have a play this weekend coming up..... touch wood!!!!
as a side note worried about the HICAS pump mod ....might have to pull the wheel in it!
Hi, I am still interested in one of these.
is it possible to just to go to dick smiths' and get a little box with 2 buttons and a led and attach the tsc to that?
also for anyone that has used ti for track work and they give different lap times for different settings?
thanks.
Hey yaf28f I'd suggest pming "mark32" about running a seperate box, its up to you how you want to do it but normally we just mount the switch directly in the dash.
Re the lap times.....we use it all the time and it makes a big difference.....but the best setting very much depends on tyres, suspension, how slippery the surface is, and maybe most of all, your driving style. Its best to have a shot with a few settings and see what you think. About 4 in the dry and 7 on a wet day on R tyres would be a good starting point
Thanks Mike, it has been ordered and should be with you within the week, I'll confirm when it is ready to send.
CONRAD yours has been ordered too :)
Feedback from one of the guys on here that bought a controller for a big hp GTR.....and he came home 3rd in the NSW Dutton Rally last weekend :cheers:
"Hi guys
Just want to let you know a have used the controller supplied by duncan team raceworx with great results, we able dial in the desired front torque. and achieve
good lap times at different events. this is very effective on cars with high horsepower.
i also have a grid dash dancer in the car which controls torque split with out the use og the g sensors and for circuit and sprint driving i would only use duncans unit, as it allows very good control. with out any diff windup which can become an issue.
the product does an outstanding job.
cheers Russell"
HI duncan,
im still new with the attesa controller, been reading the treads and slowly understanding them..let say after we install the controller, how do we choose to run back to standard mode? ie normal everyday drving? im hoping to get one for my track day used.
sorry newbie with gtr..:stupid:
p/s how long does it take to get the item to perth,wa when ordered?
Hi Jazree, if you want to run it in the normal GTR mode, just set it nice and low, 1 or 2 on the controller and you won't notice a difference, easy :D But in any case you won't get much front torque unless you are giving it a bit anyway :) as its all based on the output from the G sensors.
We currently have a unit in stock so you would get it within 5 days :D
So if for example, you had your attessa annoying the shit out of you by transferring way too much drive to the front you could put a "ceiling" on the amount of transfer?
Guest mark32
No this device won't do that, in fact it works the opposite way by bringing in the front torque transfer quicker and harder (only around corners) depending on what adjustment step it is on.
There is however one mode that does something very similar to what your talking about, but it is non adjustable, it is similar to pulling the fuse but there is still a small degree of front wheel drive. Good thing if you want to get some sideways action.
Guest
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
