jsut wondering if anyone can tell me the differences between the R33 N/A and the Turbo. aiside from the fact one has a turbo and intercooler etc to run the turbo. do they have same brake discs, etc. also inside are they exactly the same essentially. panels and everything outside is the same aswell?
cheers. Mark
https://www.sau.com.au/forums/topic/69304-na-turbo-differences/
well stronger internals, stronger gear box, lower compression clutch plate also superior, also the brakes are alot better. i dont think the interior would be much different. but apart from all that
the GT badges are red and white for turbo and green and white for non turbo :)
brakes definately are different... (unsure about gts4)
GTST: 4pot front, twin pot rears - with the NISSAN on the calipers.
GTS: ugly black things :( I dunno what they are - will let you guys know when i do the brake upgrade.
my gts has red gt badges (type-s standard)
and DaGr81 is fairly correct with the other stuff ^^^
Obvious one - tacho assy is different due to no boost gauge......
Yup, red/white badges for Type S NA's, blue/white for non-type S.
Front brakes have 2 pot calipers, rear is single pot for NA, I think the master cylinder is different as well due to the different pot volume. R33 GTS4 uses the same brake setup as the GTS/GTS25.
mines type S and has blue/white badges
lots of topics on this - use the search mate :D
basically:
brakes are better on GTSt
internals are stronger on GTSt
gearbox is stronger on GTSt
better injectors on GTSt
dash is slightly different
wheel hub is 4 stud on NA and 5 stud for GTSt
different exhaust setup due to turbo on GTSt
different ECU
better stock clutch in GTSt
thats about it i think i may have missed somehting though
Non turbo has 4 wheel studs per wheel compared to 5 on the turbo standard rims on turbo are 16" and 15" on non turbo, brakes are a definite difference, just did mine but they are ABS. Final drive ratio (diff) is also different marginally and not always LSD on N/A, the gear box I'm not sure as mine has the same number on the manaufacture plate as a turbo model. Both have HiCas.
Bah, just when I thought I'd got that one figured out.... I'll fall back to my previous theory then - red badge = sold thru Nissan red stage dealer, blue = blue stage dealer. From what a friend in Japan has told me red stage = performance stuff and blue stage = family/smaller car stuff.
hmm... mine is an NA and has red and white GT badges... also has RB25DET sticker under bonnet..... but is def NA
What does it say on the VIN plate - RB25DET or RB25DE? Where is the sticker you refer to?
mines blue and it aint exactly a family car?
Err, by family car I meant they sell cars like the Maxima, Sunny, Pulsar etc as well, I guess the NA Skylines are the top of the 'family friendly' cars?
I've got blue badges...but my car was sold by the Prince Nissan Dealership?????
I'm not sure where the Prince dealership chains fit with the Blue stage/Red stage thing.
Anyway, tis just a theory....
it could just be a possibility that the previous owner did not like the red badges and
threw on the blue to be more realistic...
blue badges are quite cool though - very rare.
Tehehe, in NZ blue badges on R33's are common as dirt, probably because there seem to be a heap of 2L GTS models around at the moment, they out-number the GTS25T's by probably 3 to 1! And GTS25's by about 100 to 1....
Yeah I prefer the blue, considering my car is blue as well it's looks good :cheers:
I used to get people staring at it funny though, cause I had blue badges, N/A exhaust, no gauges, yet they could hear the turbo :)...the Big front mount gives it away now though.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
