So how does this sound for a setup to suit a daily driven road car (R34 GTT) that sees that track once a month or so. RE55's on the track, Cheapish Falkans on the street. I am about to lower the car about an inch from stock. At this stage the car will have Bilsteins but I'm not sure about spring rates sorry.
Caster - as much as I can get. 7 degrees positive? Do I need a kit for this?
Toe - 0 front and back.
Camber - 2 degrees negative on the front and whatever lowering gives me on the rear. I'm told the R34 is adjustable on the rear so that when I lower it I can can take out some of the negative camber that is caused if it turns out to be too much. If not I guess I'll have to get a kit for this. I find the outside of my tyres both street and track (track much more obviously) wear more than the rest of the tyre.
Alternatively, I might just have to learn how to adjust the camber without a guage (some sort of markings on the right parts) so that I can change between 1 degree negative for the street and 3 for the track.
This has taken me a while to understand how it all works and at least I now understand which direction everything is moving when you adjust it but it's all theory at the moment. I'm yet to get under the car and fiddle with things myself but for a stock car it handles pretty bloody well which is why I haven't bothered until now.
I haven't mentioned sway bars yet because I'm fairly sure that R34 GTR ones fit and improve things but I'm still trying to find out if R33 and R34 ones are the same as each other (fitment wise not stiffness wise).
Also I've semi hijacked a few other peoples threads so sorry about that. This time it's all about ME! hehe.:P
Not a bad plan, my suggestions follow;
The R34GTR front stabiliser bar is too small (in rate) for a GTT, we use 24 mm on a GTR and 27 mm on a GTT. Adjustable of course. Part # BNF24XZ
The rear bar I would suggest is a 22 mm adjustable, Part # BNR11XZ
The front caster kit part # is KCA331, max adjustment should give you around 6 to 7 degrees positive caster.
The 25 mm lowering is OK for the front camber, that will give you 1 degree negative, a Whiteline camber kit will add the next 2 degrees that you will need. So max adjustment is 3 degrees negative and min adjustment in 1 degree negative. Makes it easy to have separate street and race settings. Part # KCA348
The 25 mm lowering is not OK for the rear camber, it will give you 2 degrees negative. You may be able to reduce that down to 1 degree using the standard adjuster. If not, a Whiteline camber kit will enable that. Not really necessary to have separate street and track rear camber. Part # KCA347
A rear sub-frame align & lock kit (Part # KCA349) allows diff angle change & subframe lock, essential for any serious track work.
The Whiteline spring rates are a good match for the Bilsteins, make sure you get a couple of extra circlip grooves machined into the Bilsteins (front and rear) , that way you can get the height just right for your purposes. Take a look a the Stagea Suspension thread for the details.
Hope that was of some help:cheers:
  • Like 1
That was a great amount of help thank you.
I don't understand what this does though:
Basically the rear suspension cradle houses all your susp goodies and is bolted to the underside of the car. Where it bolts there are bushes. By replacing them with nolathane, ppl often call them pineapples, just like other bushes it removes some flex/play from the susp and sharpens up the handling and makes things more predictable...it also increases NVH but i cant really tell, Skylines arent quite cars to start with:)
  • 5 weeks later...
  • 8 months later...
Well I've put the lowered springs and shocks in and went for a wheel alignment today.
.................. Before - After
Rear ..........
Toe Left ..... 0.6mm ..... 0mm
Toe right .... 3.5mm .... 0mm
Camber left.. -1,21deg .. -1,02deg
Camber right -1,31deg .. -1,01deg
Front ..........
Toe left....... -1mm ..... 0mm
Toe right .... 1.1mm .... 0mm
Camber left.. -1,19deg .. -1,17deg (not adjustable)
Camber right. -1,30deg .. -1,29deg (not adjustable)
Caster left.... +5,50deg .. same (max)
Caster right.. +5,47deg .. same (max)
The adjustable parts and uprated sway bars will have to come with more money and inclination. Not too bad in the end but more caster at least would be preferable.
are you sure the front struts aren't adjustable?
r32s have an eccentric bush at the top of the strut to control camber
What the?
R32/33/34 and Stageas have double wishbone suspension front and rear. So adjusting the strut has no effect whatsoever on camber. You have to adjust the upper control arm to change camber, for example via an adjustable bush kit. There is limited camber adjustment standard on the rear, via the upper control arm inner mount. If you need more, then you have to adjust the upper control arm via an adjustable bush kit, which gives much more adjustment than the standard adjusters.
:huh: cheers ;)
What the?
:) cheers :P
heh, i meant at the upper control arm
strut/control arm whats the difference :)
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
