Finally finished my rebuild after about 7 weeks.
Did
40 thou over rebore
Arias forgies
match ported everything
reseated valves
regasketted everything
New big end and thrust bearings
N1 oil pump
N1 turbs
S/S dumps and fronts
Os giken twin plate
Os giken adj cam gears
Gates radiator hoses
Gates timing belt
Clear cam gear cover
Acid bath
All welsh plugs changed
Oil cooler and filter relocator
Anyway I am still in run-in time and the car seems a bit less than it used to be..I know I might be jumping the gun as I can't really get up it yet. But I have been around 5500rpm ish at 0.7 bar of boost and my 33 was always the 'lesser' car power wise....Just chasing thoughts
Could it be because we opened the piping so much it will take more exhaust gas to boost?
Is the engine just so new and tight?
I am looking forward to giving it a proper boot full but I must behave for a few more hundred k's...
The next step is injectors,pump and fc in case you were wondering why they weren't on the list.
https://www.sau.com.au/forums/topic/69469-32-gtr-rebuild/
could be the run in oil as well, i think mineral oil is harsher on the internals at high temp, but thats what it needs to bed the engine etc.
sweet build!! i have just done the exact same rebuild!!
i found that during the run in it also was abit down, but i got it tuned on the run in oil and it pulled 250rwkw on pits's dyno in 3rd at 1.2bar. It was running rich with the lower comp ratio
after the oil change it seems to be much smoother and rev's alot easier. i can feel the power earlier, and it feels like it may come on harder??
i will have it dynoed at the next dyno day & post the results. also pits's dyno results are usually at least 10% low??
https://www.sau.com.au/forums/topic/69469-32-gtr-rebuild/#findComment-1285363
Guest two.06l
Did
40 thou over rebore
Arias forgies
reseated valves
N1 oil pump
N1 turbs
Os giken twin plate
Gates timing belt
Acid bath
did you open up the exhaust ports when doing the head??
https://www.sau.com.au/forums/topic/69469-32-gtr-rebuild/#findComment-1285463
ricknismo
I have an R32 - and have just done the SAME rebuild, I'm also still runnin in (~1500klms on the dial so far) – I have R34 N1s with hks style non-turbulent dumps and a full 3.5” exhaust + the other stuff you mention
At 8psi - I'm gettin ~180awkw I'd say (I can keep up with a std WRX and VYSS)
B4 the rebuild I had about 210awkw – but my bottom end was shot (pots 4 and 6 totally rooted), no dumps, no port and polish blah blah blah
It does not rev out as smoothly as it did b4 - but it I'm not expecting things to fully loosen up until past 5000klms (at least) and I have lost the mineral oil
I have the PFC + Adj CAMS + 550cc injectors + Apexi EBC to install in the next week or so.
I'm expecting somewhere near 280awkw @ 1bar once this kit is installed and tuned
https://www.sau.com.au/forums/topic/69469-32-gtr-rebuild/#findComment-1285877
  • 3 weeks later...
Had a play today...found a major boost leak.
Here's a trick...I clamped a plastic cup in the rubber hoses where the air filters go, shoved an air compressor up the (or any) air line and pressurized the whole system...found a couple of leaks...Might still have a little one though.
https://www.sau.com.au/forums/topic/69469-32-gtr-rebuild/#findComment-1316468
  • 3 weeks later...
I found the problem...Yeah.
The standard boost solenoid has a T that goes to the plenum on the same line as the actuators...This won't work with an aftermarket boost controller and stuffs around with the sensors I guess. I ran a new vacuum line dedicated to the actators and it all good now.
https://www.sau.com.au/forums/topic/69469-32-gtr-rebuild/#findComment-1353301
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
